2 hours ago, jaysevu said:
What size is the tyre and do you know what camber specs? its pretty much the look I'm aiming for.
275/35 .. Camber specs are changing this saturday again so I'll give you final numbers then.. I think front camber will be somewhere like -4.0 and -3.0 at the rear, but i'll confirm on saturday.
  • Like 1
  • 2 months later...
So it has been a while since I've updated this and there has been a lot happen since the last update... So here goes!
Bought an ARC intercooler, Ikeya Rear LCA's and ARC (Auto Refine Company) fully adjustable sway bars
22243941_10155944063440572_787396258_o.j
22251174_10155944063455572_1157249532_o.
You can see the difference to stock sway bars here.. These made a world of difference to the handling. (I probably should've done them sooner)
22882372_10156011439355572_2042137415_o.
Fitted them along with the Ikeya rear LCA's.
22908301_10156011440540572_770743771_o.j
Fitted the ARC Intercooler as the stock one was looking worse for wear, and I actually picked up throttle response as a result!!
Now the front end looks so much cleaner!
Then we had an event to promote Gran Turismo Sport at World Time Attack and I had the privilege to be on track with many other great cars!
17-_World-_Time-_Attack-fri-_Gran-_Touri
22556276_10155979199380572_567164560_o.j
22497331_10155979199375572_285394210_o1.
Also managed to snap a shot of Keiichi Tsuchiya with my car after I got to drive on track with him!
22365327_10155967360895572_1428439061158
  • Like 5
And now that all of the suspension components have been changed to fully adjustable gear, it was time to upgrade the brakes!
So final pic with standard Brembos on it.
Then we started to get to work and pulled everything off..
Cut a small section off the backing plate and the hub (part that holds the factory brake line in place) then fitted the adapter.
I love how good these things look and how massive they are!
So skipping ahead, we mounted the brackets and calipers and got to work on fitting the braided lines and modifying the hard lines to suit..
For the rears we used the Supertec bells as it was so much easier and has a big weight saving too, compared to the standard R35 units..
While we were at it, we upgraded to the BM57 as it utilizes a larger bore and improves pedal feel etc etc.
Finally mounted the rotors
Bled the brakes and used only the best fluid available.
Hosed down the underbody to remove any potential brake fluid lingering around.
End Result.....
I cannot begin to explain how big of a difference this made over the standard brembos, you need to experience it to understand, and i'm only using the standard brembo pads that came from factory with the calipers.
  • Like 8
  • 3 months later...
So I haven't updated this in a while because no time/lazy.
A lot has happened in the past month and I finally accumulated the parts I needed to get things moving.
So here's a pic as it tells a 1000 words.
Expecting it to be tuned within the next 2 days on 98 and E85.
Parts added are:
(1.2mm Tomei headgasket is already done)
Kelford 272 degree cams
Kelford Beehive valve springs and Ti retainers
Tomei cam gears
ARP2000 headstuds
Plazmaman fuel rail
ID 1700cc Injectors
FPG twin 460 walbro in-tank setup
HKS T51R SPL BB
HKS 60mm GTII wastegate
4inch from the dump pipe down to an ARC 4inch titanium exhaust
  • Like 5
So tuning is finally complete!!
It's now making 364rwkw (23psi) on pump 98 and 472rwkw on E85 (30psi) and rev limit has been upped to 8,500rpm.
Kept it relatively safe because I care about the motor!. Will take it down to the strip and just do a mph run to see what it's capable of soon.
27797366_752298338303975_1017356259249621825_o.thumb.jpg.1f2a3f8d929fabd6eb0dde7bd383f3fd.jpg27912608_752298364970639_6929231197397456618_o.thumb.jpg.51021f22466367d44bc760cc740af638.jpg
  • Like 7
It is great seeing other people's setup and appreciating the hard work and $$$ that have gone into the build.
The gauges look great. Do you have a wider angle pic showing how they fit into the interior?
  • Like 1
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
