Hey guys i recently joint this forums.
I am having issues with my R34 GTR oil catch can filled up so quickly and poring out in engine bay.
first of all it is a highly build 900whp rb26 so i launched the car from 0 and leaked oil and all over went straight to the front tire.. end up with small accident rim, control arm & bumper.
so i had a this custom catch can build for me and it failed. So both valve covers has -12 lines to catch can about 1 quart with side filter.
any recommendations..
Sounds like you have a major problem. How long ago was it built? Has it always spewed oil? Patrick may be right - it could be an engine out job but have a read of the last half or so of this thread:
http://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/
Thanks for the quick responds.
few months ago, was fully build. i have driven this car much its more like a show car, how ever, i drove car on road to and on the dyno breaking in the motor and after that tune it for 4 hours on dyno @ 9500 rpm did massive power and 0 oil in catch can.....
i drove the car around is great healthy nice power and i did first launch on car to see how it s from dead stop at 7000 rpm and drove it few miles and another launch. and started slide and hit rim at curve.
and thats when i discovered oil every where from catch can.
it is high compression build and is good no problem very healthy.
was thinking maybe i need to upgrade the valve cover to mines foam setup. and biger can...????
i'll get some photos to share
What restrictors, it just seems like something has happened after your launches, at the power levels you are talking about it won't take much for bad things to happen.
Hell, at 900 HP I recon if you get more than a couple of thousand k before a rebuild you are doing well.
And one big lean run and games over.
That can looks like it was designed to spew oil, how much baffling is in there.
Have a good read of the link that Bob posted.
BTW lots of nice shiny stuff, get that thing sorted.
well patrick so i do have the stock restrictors and valve cover factory baffle.
i did install -10 head oil drain on back of head. and i was pissed off that inside of the catch can there no baffle foam or anything.
IMG 0641
"Head drain" is a waste of space. Read the oil control thread - strangely enough the answers are all in there. BTW what oil pump do you have?
But I thought the head oil drain is very important sense it get flooded with oil in the head .
And I have nitto pump
But it's not a drain. It's a shame you are running stock restrictors
Let's say it takes you three hours to read the oil control thread. Pay yourself $33 an hour that's $100. Say your pump empties the sump and you run the bearings or put a rod through the side - what's that going to cost you? Do the research, come up with a plan and people will let you know if its the right one if you're still not sure.
after reading for hours, well first of all thank you guys.
I did come to understand this oil issue.
I was looking at my block when did the job, it did have one restrictor on the front (2001 rb26 v spec ii)
so i don't have to worry about the rear.
I also do have NITTO oil pump and i do street race, and some track.
IMG 0082
so guys i don't know in Australia but in USA, they don't care about legal stuff like catch can need to be routed to the turbo, pcv deal. i don't think its healthy.
so i can with my plan and guys feel free to correct me
1) pull the head out,
2) port the head oil drainage to gasket size
3) Buy oil restrictors 1mm to be installed in front (heavy foot street race high rpm and some track ) tomei brand
4) Drill/port the block oil drainage lines with 10mm drill bit ( can the waste be flashed with the oil few times?) or
is it a must to pull that sucker out?
5)buy fuel cell foam and build a better baffle in the valve cover.
6)and build new catch can with baffle in side. 2x -12 and tom mounted filter
7) external head oil drain already installed. -10 to lower block.
8) use 10w60 fully synthetic oil
do i need to do anything inside my stock oil pan it is currently stock. with diff.
First I would get a compression and leak down test done.
Then if all is well I would go the restrictor.
See how it goes and maybe get a well engineered can if needed.(Sorry but I really don't like the engineering, or lack of, of your current catch can)
But that's me.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
    • Careful with posts like that around here without the flame suit on @cobo_11! 😂😂 My 330i journal is on here too. That car was so good and super reliable. We still have a 130i in the family which is almost identical to the 330i and easier to find in manual. It has also been almost faultless over the 6 or so years in the family.  I used to want an M car a lot more than I do now but if I'm honest and without trying to sound like a wanker, I can get such good performance and handling out of my 335 without needing to worry about all the crap that goes along with M car ownership. I don't need to worry about my bearings or subframe issues or the cost of replacing brakes or suspension or whether it has been impeccably maintained. And I can leave it places and not get upset when it's always filthy.
