No longer own a 33 GTR :glare:
Have a bunch of random parts, some are new some are old.
Prefer to sell them all together, but will separate if enough interest, not really sure what they are worth so take the lot for $200.
Main items for sale are;
Stock R33 GTR ECU, my car was a 95 from memory. - $100
Never used RB26 Clear Timing cover - $70
Random Gaskets - they look like exhaust/turbo, thermostat, possibly a rear main seal? and a few that i can't remember what they are for. Pics tell the story for that one. - $50
Self made RWD Switch for the R33 - Worked great, factory blank panel ready to pop in - $10
Brand new handbrake cover, black with blue stitching - $15
Pod filter Cover, Air Dancer? :woot: - $10
Stock Cam Gears, used but are in good condition - $50
Aftermarket stereo connectors ready for your new headunit - $2
Pics of everything is here
http://imgur.com/a/QN2oC
Pickup - Diamond Creek, Victoria.
Will post at buyers expense
Edited by Booki
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
