I have a 2009 Skyline crossover (370GT) and yesterday I was happily driving along with the airconditioning on and the car seemed to hiccup a couple of times and as I pulled up to a red light it stalled... I restarted the car and immediately heard a strange noise that sounded like (for some reason) the AC compressor? I flicked the Aircon off and the noise immediately stopped and the car carried on fine...
Pulled off onto a quiet road and with the car sitting still in park, I turned the AC on again... There was a cyclic noise, a bad noise - and the engine revs dropped significantly in time with the bad (graunchy) noise - every 3-4 seconds...
Turned the Aircon off and drove home with no issues at all.
I popped open the bonnet today and turned the engine on (again, in Park) and no issues - but when I turned the AC on, it again made a horrible noise... By the time I got out of the car and around to the front to look and see if I could see anything (fat chance with how tightly it's all packed in) there was smoke coming up from the front of the engine. Dived back inside and killed the engine of course.
The smoke was not oil smoke - it smelled acrid - like burning plastic or rubber.
Does this sound like a toasted/seized AC compressor? If that's the case, what am I up for? New compressor, system recharge and possibly a new accessory belt + some labour?
What else might it be? I'm probably going to take it in tomorrow to have someone look at it but if there's a common failure or conventional wisdom on this then I'd love to be prepared.
I'd hate to think what may have happened if I hadn't noticed the noise and turned off the aircon within 4-5 seconds of noticing the noise/smell each of the 3 times it happened.... It took no time at all to generate significant amounts of smoke. (FWIW - I do have a fire extinguisher in the car beside the spare wheel and one on the wall of the garage about 5 metres from where I was standing)
Cheers - Neil G
Edited by talkiet
it does sound like a seized compressor, the smoke would have been the slipping belt, much longer and the belt would have likely just snapped.
As for the repair.. I would guess at minimum you would be looking at a new compressor, and I would replace the belt too, then a leak check and gas recharge.
At worst, the failure could have pushed metal fragments through the AC system and the whole system could need to be flushed and some other components possibly replaced if they can't be properly flushed out.
Thanks for that... It was only the last of the three events where I saw smoke and the other 2 were definitely still producing some AC - it was pretty clear there was some movement in the compressor - it was slipping, not seized... It may we have completely seized now though with the last one. I'll throw it at a professional tomorrow and hope for the best - thanks for the quick confirmation I'm probably on the right track at least.
Cheers - N
Ouch - just had a look at the cost of a new compressor from Japan... $900 USD excluding the clutch, $280 for the clutch. I wonder if I could get incredibly lucky and it just be the clutch that has failed?
Cheers - N
From what I've seen in the past on similar issues, it's most likely the bearings. If it were clutch, the A/C would never engage and that pulley would continue to rotate freely. The fact it only seizes when the A/C is on means the clutch is engaging but the bearings are probably locked solid.
But that's just a best educated guess. You'll find out when you get the report back from the A/C guy. Good luck!
I phoned an aircon place this morning and described the symptoms in detail... The guy said that his first guess was the bearings either badly on the way out or actually locked solid. Hopefully it hasn't blown up the entire pump...
I'm dropping the car off in the morning and for the sake of completeness I'll update when I have a diagnosis
Cheers - N
Ugh... system degassed and drained. There is a small amount of crap in the fluid and the bearing is fine... The resistance is coming from the compressor itself. So they are looking for a replacement pump and I am steeling myself for a significant expense :-(
Fortunately the car is still perfectly usable in the current state and the pressure interlock means I can't even accidentally turn on the AC pump, but I can still use the heater ok.
Cheers - N
Bummer. It's easy to keep the A/C from engaging accidentally in a worst case scenario anyway ... just unplug the electrical connector which engages the clutch.
At any rate, not the best outcome but shit happens with these money pits called cars.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
