Hey guys having some trouble with my skyline cranking over.
About 2 months ago I started having trouble with my skyline. She cranks over fine but has trouble firing. After a few goes she would finally start. It's getting fuel, the injectors have pulse, it's getting spark, afm has been replaced, cas has been checked and fuses have been checked and it still won't start. Seems to work fine some days (generally doesn't start at night time). Went into limp mode yesterday but ran great today until tonight. It'll just keep cranking but not actually grab and fire. Any help would be great cheers
Gtst r33 1996 with pretty much every mod you can think of.
https://www.sau.com.au/forums/topic/464282-r33-gtst-wont-start/
My snide comment may not have been helpful either, in hindsight.
Mods may play a big part, for instance your coilpacks - are they stock, LS, Splitfire etc?
"pretty much every mod you can think of" could well be a lot of stuff that doesn't help or could cause a lot of problems. Instead of letting people think of lots of uninstalled crap, just list the more main items.
Just might help in diagnosing.
Car when revved over 2000rpm would want to stall and hesitate to respond. Had to drive home pretty much on gravity or under 2000rpm
Another thing I thought of is I have a gasket cover leak and noticed some "good oil" on my spark plug. Maybe the oil is stopping it from sparking?
Yes I read that before. That however doesn't answer my question lol..
There's a difference between revving a car while stationary or revving a car while under load.
In the case of oil leaking from your rocker covers you'd be best pulling off your valley cover and removing your coil packs.
If you do see oil leaking into those cylinders make sure you grab a rag and soak up all of the oil rather than removing each spark plug and letting the oil drain on to your pistons
What changes have you made over the last 3 months?
Edited by jmknights93
Just a stock Ecu
Wouldn't start last night, would just crank over but not grab. Went to try again this morning and it started. It's showing signs of a bad crank angle sensor although it's been checked. It back fires and misfires once it starts and wants to stall while the car is running not stationary until it warms properly. Also revs very high, I've also checked for a vacuum leak
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
