Hi, i have finnished a RB30/26 build now for my drift car that will se around 800-850whp.
Im currently sitting on a stock gearbox and that wont last long with semi slicks tyres.
So im looking for a uprated gear set for my 25 housing and decided to go for a straight cut.
A company here in Sweden just started importing the PAR gear sets, i did some searching around SAU and found that it was not so much positive information to read about PAR engineering.
But that was from about 08 to -12 then it goes quiet.
Have PAR gotten their shit togeather or did just people stop buying their products?
Here in Sweden it's like half the price for the PAR kit vs a PPG kit so i thought it was worth asking.
So are they still shit and what was the problem back in the days when they failed?
And do you guys know if anyone use them for drifting now days?
https://www.sau.com.au/forums/topic/464286-par-engineering/
I saw the same, they had a run of problems and then have gone quiet. I'm going to try them for my next box, my car doesn't make big power and I'm willing to take a chance to save that much....
Occasionally the top boxes like hollinger come up on here 2nd hand under $20k, but what everyone forgets with them is the cost of the annual rebuild at hollinger prices...
https://www.sau.com.au/forums/topic/464286-par-engineering/#findComment-7714092
I have problem and same question so i build my motor and i end up with 900whp on BNR34 GTR it is a v pec ii
i did few launches and gear box is ok i did fully rebuild it with all new factory gears and i am using it now and feels good.
how ever i do have question about the axels in front and rear can they handle the power and i don't like how my diff not locking. It suppose to be since awd straight forward. car did snake shape i prefer to just lock the diff... what people have done with this massive power.
Any recommendation can help. Thanks.
IMG 0634
https://www.sau.com.au/forums/topic/464286-par-engineering/#findComment-7714098
At the top of this page the second "pinned" thread is about the computer controlled LSD in the back of your V-Spec. If you read all of it (its not too much) you will find out how to service your diff so that it works properly. If you can afford it now wold be a good time to put a Quaife LSD in the front of your car (available from Palmside in Christchurch NZ) and if you have the time and inclination there is information in this section on how to beef up your transfer case (with a GTR the spending never ends!)
https://www.sau.com.au/forums/topic/464286-par-engineering/#findComment-7714260
Word of warning regarding gerrard and PAR gearsets. Stay thafuq away from them. Searching my gearbox threads will explains
Yeah i have seen that you have had your fair share of problems with PAR.
What was your main problem with the kit? braking the gears?
https://www.sau.com.au/forums/topic/464286-par-engineering/#findComment-7714496
I know of two people using PAR gear sets and they swear by them. One is actually an engineer for BMW and builds some very impressive track cars.
I've heard they have come a long way since 2009-2012.
Apparently some of the quickest 35s in the world are using PAR gears.
I'm in the same boat and was looking at PAR however might just go the PPG or seq route
https://www.sau.com.au/forums/topic/464286-par-engineering/#findComment-7715793
My pulsar runs a PAR gearset, previous owner went through the whole process so i can only really pass on what he said and other pulsar peoples opinions...
He said they make a good product, but workmanship wasnt consistent (this was prior to 2011). Gearbox was sent back 2-3 times to be re-assembled properly.
Ever since ive had it, the gearbox has been a dream (touch wood). Its the best manual ive driven, i love it. Can treat it like a dirty broad minded person or baby it. I do use their recommended Neo gearbox oil though, which aint too cheap.
https://www.sau.com.au/forums/topic/464286-par-engineering/#findComment-7716618
800hp RB25/30 drift daily driver whut, crazy Swedes... :P
What's wrong with helical cut gears? Or are you after straight cut whine?
Hehe, yeah it's pretty close to a competition car without a rollcage. But it passed the MOT last year so it's "street legal"
I just think that straight cut vill be stronger. I dont know how many that have killed a OS giken gear set but i know that i would kill my self if i bought one for that amount of money and it went suicide on me..
https://www.sau.com.au/forums/topic/464286-par-engineering/#findComment-7719893
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
