Suuuuuuuuuuuutututuututuuuuuuuuuuuuu dose is life.
Harro betches,
Up for sale is my old 3" cat back exhaust which has been on my car for a while. It has gone through a few changes over my ownership. Started off stock with the stupid taper in the resonator...so I chopped it off and replaced it with a 3" straight through resonator. 3x weeks later, I wanted it even more quiet so I proceeded with adding a 3" mid muffler. It really shut things up. I can now have long d&ms in the car with the missus whilst listening to smooth FM without any hint of drone or bullshit......... until I crack the gate.
So what are you getting?
R33 GTS(-t) 3" Fujitsubo Cat Back Exhaust with:
  • 3" X-Force Straight through Resonator
  • 3" X-Force Straight through Mid Muffler
  • Bolts/nuts for the rear section
  • A part of the shit box's legacy of choppage
If that excites you enough, and you want a car that is actually quiet, fun to drive and not a total cop magnet.. then this is the exhaust for you.
Condition: Decent, a few grazes but no dents on mufflers or resonator, however a slight decent on the rear piping. Also 1x pin hole on the last bend as per the photo.
Price: $239.95 (that means $200 firm)
  • Like 1
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
