I don't mean to knock you so don't take it personally, but isn't that power figure really Poor?
I mean I got a similar figure when I had my R32 with an exhaust, filter, rb25 turbo and 11psi..
and alot of guys get over 160rwkw with stock rb20 turbo..
surely this is not normal for an R34 GTT
unless it's auto.. maybe?
Nah its a manual not a wussbox :P
Ummm.. Im in Bathurst which is about 700 - 800m higher than you Sydney guys if that makes much of a difference. (I know it did years ago back in the Dark ages of carbys)
Let's clear something up here, R32 GTST, R32 GTR, R33 GTST, R33 GTR and R34 GTT all have ceramic turbines.  R32 GTST, R32 GTR, R33 GTST, R33 GTR have steel compressor wheels.  These turbos are made by Garrett for Nissan using Nissan tooling.  Although I have seen a couple of late R33 GTST's with plastic compressor wheels.  All R34 GTT's I have seen have plastic compresor wheels.  These turbos are made by Hitachi for Nissan using Nissan tooling.
I have never seen a problem with the plastic compressor wheels, it's the ceramic turbines that are subject to failure at high boost and/or temperature.
The type of turbo fitted has nothing to do with the overboost protection, its dependant on the ECU. :(
what tipe of turbos do r33 gtrs have dude (you sure know alotabout these cars)
:):cheers:
