Hi all,
thinking about buying one of these for an oil cooler set up. i like the built in thermostat and i really dont want to fit a relocator.
the hicas is removed so there is more room.
does anyone here have it fitted to there bnr32? to me it looks like there isnt enough room. am i wrong?
pic of said sandwhich plate
nengun-3025-04-greddy-oil_sensor_adapter
Hi all,
Pictures and information in my build thread on page 6. NO CLUE about factory manifold and such, but I'm sure it's possible. I had mine in several different arrangements starting with your idea, and then moving to the final idea of relocating the oil filter as well... Note where my temp pickup is located, this is on the RETURN side from the oil cooler so that you know what the temp of the oil is going into the engine.
Need to remove standard oil cooler
The heat exchanger? You don't. I've fitted a few of these now to 32, 33 and 34 and they all fit. They're a little annoying because where the cooler hose comes from is very close to the engine mount, I'm talking 1cm close. It can be done and they're actually a great piece of kit that after fitting 10+ of them I put one on mine as well.
Well there you go
Also the two additional fittings they send are blanked. They also sell some that are tapped 1/8 but this is NOT NPT, it's PT (Japanese). I drilled and tapped my blank ones for my temp and pressure sensor pickups.
was thinking that.
i noticed the coolers with the -10 outlets are considerable cheaper than the -12 ones.
im thinking most people buy the -10 ones?
in my mind im thinking bigger is better, no?
what are peoples thoughts on buying a oil cooler with -10 outlets and buying a -10 to -12 hose end?
was thinking that.
Also interested in reasoning of -10 vs -12
I would have thought you may see a pressure drop?
In the process of fitting my oil cooler setup without relocation. Extra parts required on top of kit was
oil filter stud - purchased from kudos Motorsport
Trust/greedy sensor adapter to fit factory oil pressure sender. The oil temp sensor won't fit unless you get an adapter to step up. I am going to be running aftermarket oil temp/pressure gauge which will come with correct sensor fitting 1/8 npt if I'm not mistaken.
I have not fitted a relief valve to my N1 block but will be running a filter that runs one.
I have chosen to remove the heat exchanger but this is not a must. Clears up a lot of space which I like. Obviously the factory coolant lines that feed heat exchanger will need to be bunged if going down this path.
Manifold is fitted in photo.
Edited by wld093
1) I don't think the hole from the block that sends oil is 1/2" in diameter but it's been a while since I looked at it. -10AN is approximately .5" in diameter and is AMPLE (IMO) for the oil flow in most engines unless you are running something crazy I don't know about.
2) The Greddy kit fittings are -10AN fittings. I'd assume they would send -12AN if it were required for our engines.
looks great. from the replies in this thread i have decided to keep the factory heat exchanger so i dont see why i would need the additional sensor adapter. i was however under the impression that the sandwhich plate came with a stud. ill have to check what i have bought.
after all that i bought i the -12 version. ill be going -12 everything.
I am wondering what the oil flow is if you have the factory exchanger in place. I have mine laying around and may want to see what the flow is doing before you decide to leave it. If it's first in line the temp reading won't be what's actually going back into the engine and if it's last in line the work from your external cooler would be undone from the exchanger reheating it.
Just a thought. Oil flows out from the block on the outside of the oil boss and back into the engine through the center bolt FYI.
  • 3 months later...
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
