Hi
First of all I thought I'd introduce myself. My name is Campbell, 28 years young and have a strong passion for cars, bikes and well anything Motorsport & with a bloody engine! Will give the time of day for anyone at a car event no matter their car, in the end we are all there for the same reason, the drive and passion for the cold steel rolling chassis we love.
ANYWAY - enough about me onto the car
Introducing a 1993 model, R33 GTST Four Door, was purchased out of a backyard locally in town, she was in bad shape. It had been ratted for parts 2 weeks prior to me buying it. Had a list of things missing, and a 1.5" hole in the block...
I got it towed to work, the beauty about having a workshop big enough that after hours and on weekends I can muck around and see what I had purchased, shocked with what $500 had got me. Within the first hour I had landed on a mini gold mine, Rays Engineering Evo3 rims, bilstein suspension all round, whiteline sway bars front & rear, HKS Log style exhaust manifold & Turbonetics Turbo, and this was the blow away a freaking Link G4 ECU! Crossed my fingers that the stock auto had some sort of high stall converter & shift kit but that was still unknown
At this stage, I was not sure what to do...part it further and make my money back and then some...or give this ole girl a new life... I was undecided if I was going to join my local car club and use this as a track car, not ideal being a four door, but for a $500 shell I was not complaining at the time.
After a little research, I had decided to keep what I had and go on the hunt for a replacement engine. Around $1540 later I had scored myself a replacement RB25DET motor, copy GReedy intake manifold, throttle body, 1000 I.D injectors, Tomi reg and rail. At this stage I had removed the old holy engine, pulled it down and from memory number 5 rod had rolled around made one hell of a mess and wanted to escape out the side.
Trying to shorten this story a little, as I know some readers are just looking at the images now, but the engine I had received had sad ring glands, this is common to the RB engine when more boost and lack of fuel goes into said motor so I was told. The engine was stripped down, more crappy news as the crank was also slightly bent, so in the end of the day I had one good block and head. A friend of mine sold me a Rb26 short engine for cheap, although it needed some lovin, I removed the Rb26 crank, rods, oil pump and took to the engine builder. He made a good clean short RB26 engine, in my existing block, done a few extra things while I was there, grub screwed the crank and also threw in some forged CP Pistons. The head was overhauled and hey presto, I had a new RB26/25 motor.
At the same time the turbo was removed and rebuilt, HKS log manifold sold off and replaced with a steam pipe high mount. Intercooler and home made pipe works.
With this setup, car running and slowly being run in on the dyno, it was then found out the automatic gearbox had a stage 2 shift kit and a mild stall converter, that being said she made 290kw at the wheels. This alone was fun enough to own, 290kw, shitty grey R33 4Door skyline. Had plenty of power and left a nice number 11.
A couple months past and my original idea using this as a track car came back into play, the automatic gearbox was removed, as I purchased a wreck from the auctions. I used the manual and all bits required to make it work in mine. The wiring was easy to make work also with the help of the internet. Back on the dyno from auto to manual we got 330kw with less boost which is only normal as the converter sucks up some of that power.
Next on the imaginary list of shiz to do was a fresh paint job, Cherry Black with some Red candy to get some depth into it..Now I don't know if anyone else reading as ever done a full body respray but quite a few long pizza fueled nights and two months later it was a bloody good job well done.
And, well I was proud to compete Saturday just gone in my very first ever track day, let me just say what a amazing experience it was! The rush, feel and response from your car when you are legally racing around a track. The local track is small, but still worth it! My plans now with this boat is to invest in some new tyres before next month and see a tyre & suspension shop for some advice on setup with the front wheels.
Well thats me & my 4dr - Feel free to ask questions, and add some advice into camber setup on this thing. I am a little lost here and just started researching it today.
Thank you for taking the time to check this out
  • Like 5
Thanks for the positive feedback so far, it has come a long way.
Going to try and get outa work early or at lunch to talk about the camber on this, will I need to invest in adjustable arms?
Yep and adjustable castor rods (if not already fitted).
Build thread!! This is awesome! Well done!
Did I post this in the wrong area on the site?
So got on the phone to Hard Race Performance today, and their upper front arms will give me -5 camber. This arm uses a spherical bearing, they also have a harden rubber option available.
I am yet to head to my local brake and wheel alignment shop later this week to see what they want me to do under there also.
Tyres are the next issue, so many semi slick options out there but I've been pointed in the direction to look into Hankook Ventus Z221 - Rim size I have are 17x8 on the front and 17x9 on the rear. Tyre pattern below, just looks the goods...post-139747-0-29240700-1461033332_thumb.png
Plan to keep this thread up to date through out the year with car shows, modifications and track days! :)
No no! This is a good spot for a summary. Build threads go into more detail and are kept up to date as things progress. You might get more people taking an interest in your car in a build thread.
We can convert this to one if you'd like? It looks like you're going to keep it up to date anyway.
Looks like a good project, I love seeing potential wrecker fodder retreived and made whole again!
$500 was a good buy, but I suspect this will be an insignificant project by the time your finished ;-).
Cheers
Brett
That would be awesome, get this out there more and some more feedback would be great. Just wanted to show the other 4 door guys what I've been up to :)
Can you paste a link to where it gets moved to?
Cheers,
I still need to drive it to & from the track - Full slicks are not road legal are they?
nope. and some track days/insurance wont allow people to run slicks without a 6 point cage. it can also introduce new issues to oil and fuel supply, though some get by just fine.
So below images are of what the turbo setup was before to how it sits today.
There was a HKS Log style manifold that came with this car when I purchased it, I did use it for a little while around 6 months, but the oil return from the turbo core to the block was not big enough. I noticed after starting up the car from cold, and not touching anything and letting it idle it would smoke, until the engine came up to operating temp. I found out after changing the manifold setup and oil return likes to dash 12 this issue went away, so my guess is that the oil was to thick when cold, backing up in the oil return line and passing through the oil seals in the core of the turbo.
Images of the two setups below, what is your opinion of the two setups below. I like the high mount option, way easier to work on when needed!
One image I found of changing out the auto to manual
Still waiting to get the car over to the wheel alignment shop this week to see what options I have for camber adjustment!
Cheers,
Cheers,
Moving it now, I'll leave a link in the old forum for it also. :thumbsup:
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
