Hi guys, I recently bought some 15mm spacers for my rear wheels as the wheels more slightly tucked away and the fitment and extra width is perfect and I'm also enjoying the nice stance but I noticed that on rough turners it scrapes a little. What are my options of clearing an extra 5-10mm on the guards which would be perfect?
Thanks everyone in advance! :yes:
https://www.sau.com.au/forums/topic/464321-how-to-clear-guards-by-around-10mm/
Roll the guard lips; that will get you the extra clearance you need.
Yeah, I'm still trying to find a good place to do it right as I don't want the rolled guard look with the little thin flare on the edges and lose my current nice flush look. Such a tricky process.
Your sig doesn't indicate where you live; you might get a recommendation if people know where you come from. ;)
Very true sorry guys. I live in the western suburbs of Melbourne. I've tried giving Phat Guard Rolling + LowDown Guard Rolling and they both never return my calls. They can't be that busy and even if so, they should at least take calls and booking...surely I must have an old number or something?
Thanks guys.
Thanks guys.
Some suspension specialist will do guard rolling; especially if they deal with a lot of performance cars.
It might be worth seeking one local to you and seeing if they do, or of they have someone that they use.
Cheers mate...just got some PM's suggesting Suspension Centre in Kealba VIC apparently they're really good and helpful. I'll give them a call - would have still preferred one of the above mobile guard rollers as I have young kids so it's very hard for me to go anywhere without my wife nagging! :yes:
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
