RE Spacers: There are bolt-on (min 15mm I believe) and slip-on, which is just a piece metal with holes in it. Hub centric means the hub hole is manufactured so it sits on your hub properly, instead of having a generic size (73mm or something).
The bolt-on spacers I've seen are hub centric (e.g. GKTech, meaning the hub hole is 66.1mm Nissan size).
Lipping/rolling isn't that hard, just get a heat gun to heat up paint and a roller (I bought an ebay one from Adelaide for $180-ish). Need patience and good smooth movements.
Slip-on spacers come in <15mm but definitely not recommended.
Hub centrics are the way to go but the minimum thickness is either 15mm or 20mm.
OP have you considered the obvious solution - just add negative camber? It'll keep the look and reduce rubbing, at the cost of tyre wear and handling. #stancedyo
Gk tech do, or did, a 10mm slipon hubcentric..i know, i have some lol. Have widened guards a little on rear but have a cpl different sizes of hubc spacers to get the 'right' fit, works well
Just be mindful with the rolling to use lots of heat. I had a backyard job done on my rear guards, one ok one cracked, great fun trying to repair the paint.
If you want a proper job done talk to Try Track, they have a specialist who does expensive cars. This said I was quoted $300 plus for rears only... But as most things I'm guessing you get what you pay for.
Appreciate the advice mate. Considering I only need around 5mm of my rear guards flared and I'm taking it to The Suspension Centre in Kealba who apparently have done this many times, I'm hopeful they shouldn't crack but I will remind them to apply plenty of heat.
Cheers mate
Maybe, just maybe, buy rims and tyres that fit?
Well, the problem is actually the reverse...my tires and rims fit fine on my R33 GTR but then I wanted the wide body look so got my rear and front guards flared (properly with extra body work done etc) - and the end results of great but then I realised my rear wheels were slightly a bit tucked away so I bought 15mm hub-centric spacers and it now looks great but is slightly scraping a bit over rough bumps or when I turn at high speeds so I measured and it looks like I will need to get a minor guard roll on the rears that will give my wheels around 5mm extra and then it's smooth sailing. And now, I can't afford to buy new wheels or tires now... :woot:
I think you're right mate...I got hub-centric spacers and have not found any smaller than 15mm that fits flush and the ones I got are made specifically for Nissans so all good there, but then I will need a minor guard roll for clear around 5mm extra space for hard turns at high speeds and high bumps etc. I have looked at videos and done some research and you're right doing it myself wouldn't be too difficult, but I lack experience so I can't afford to have any mishaps and regret it - also, I don't want to fork out about $200 for the guard rolling tool when most likely I will only ever use it once or twice. That's why I'd just rather go pay someone around $150 to do it for me professionally to reduce the risk of paint cracking and it will be done nicely.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
