8 hours ago, admS15 said:
Are you using the anti lag/launch off the line or just doing it manually?
Yeah got anti lag on set at 4k. Can't do WOT launch though haha. Think I'm launching with 10 or 12 pound boost. That 11.7 run was at about 3/4 throttle in first then WOT in 2nd.
Just a small update... Finally got my windows tinted. Nice 15% on it, looks heaps better and now my right arm won't get as much of a tan ? Also got a set of Work Emotion CR-Kai's in 18x8.5 +35 fronts and 18x9.5 +38 rears. 100x better than my other wheels. Just need to get some good rubber on em! Any recommendations? Thinking about just going RS3s again as they've performed really well. 245 fronts and 265 rear should look good on them :)
Will look a pulling my head off and get it all reco'd with the new cams, studs, gasket etc at tax time. Still not sure if I wanna give the nistune another chance or just go to a link g4 straight up. The idle hunting and stalling is really pissing me off and also cold start is a bitch now.
  • Like 1
5 hours ago, vxsr33 said:
Damn that looks mint.
Only thing i would do is swap the tailights for the stock ones.
Cheers man! Yeah I have a set of stock tail lights at home but I'm too lazy to pull them out and change them ?
Probably one of my favourite pics of the car!
Have decided I'm going to try a set of Nankang NS-2R's on the 18's in a 265/35r18. Might put the 235 proxes that are on the rear up front for now and if the Nankang's are good ill throw a set up front in 235 or 245.
Got the Nankang NS-2Rs put on the rear. Fills the guards way better. I could only get the 180 treadwear rating ones for some reason.... They are f**ked when theyre cold, so slippery. Seem to be ok when theyre warm. Still haven't tested them properly yet though. Will probably go out to willowbank on Wednesday for a run with my mate who just got his 33 tuned.
  • Like 2
Saw the video on Facebook today, sounded awesome! Looks much better with the new wheels too.
I ended up ordering the subframe and front and rear diff bushings like you did  with yours the other day - have a mate at a parts shop who got it for half price. What ended up happening with your bushes that fvcked out for the front of the diff, did you find out why that happened?
Yeah cheers man, really happy with how it went and the new look!
Nfi with the front bushes, I need to check them to see if they haven't done it again. If it has i'll be going to solid front bushes..
On another note I'm still losing slight traction in 2nd. I'm gonna take it down to get 0.5-1 degree of camber out of the rear which should hopefully allow me to hook up a bit better. Ill take it down the strip after winternats and see how she goes!
3 hours ago, klutched said:
So I just checked my pinion bushes anddddd it's done the same thing... Looks like ill have to get some solid bushes in there...
Ugghh that's disappointing. I wonder if it would be worthwhile adding a washer to the top side too?
I'm not sure, definitely something wrong as the same thing happened on both sets.
I have ordered a diff bush kit from Gktech and also a poly gearbox mount. Hopefully get it all in before Roll Racing this Saturday.
When you pulled the original factory bushes out, what condition where they in?
They were fine, I'm thinking it could be because I put the Nismo LSD in? All the hopping and shit from it could have cause it.
I reckon they should be able to take that for a while longer. There only a month or two old aren't they. Maybe start a new thread about it and see if others that have experienced similar can steer you in the right direction of the cause. Cheers.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
