Got her on the dyno yesterday. Did a bit of a tune up but couldn't get it to hook up doing a full throttle run even easing onto it. Definitely need to get her on a dyno to finish the tune off.
Got her off the dyno with mickeys bolted on and holy sheet. It holds 25psi perfectly at full throttle and mickeys grip up and take off.
Booked into roll racing tonight so will be interesting how we go on first outing. Cars probably only on 700-750whp with still more timing to go at this boost.
Quick vid for yas 684whp 23psi 73% throttle 8000rpm.
  • Like 4
Couple more vids, car is amazing to drive. Only thing is it chewed my a/c belt and also spat my powersteering belt after, from hitting limiter in first. What has everyone done to keep their belts on and alive?!
  • Like 1
Weather was mint in brissy today so I took her out for a stroll. Went and got the groceries, then mate decided to come round for a cruise on his bike. Of course had to hand out the smack down show him who's boss ? Only a little MT09, but he also has an R1 that I'll line up when we get home next weekend.
Little vid with some GPS action as well.
Enjoy :)
  • Like 1
Quick update, took her out to Roll Racing on Saturday night for a shake down run. Car went well apart from 1 small issue. Went out to give my mate a run in his 2J RX7. Waited in line then was about to do my warmup skid and coolant started pissing out the overflow bottle. Shut her down and waited for her to cool a bit and drove her back into the pits. Upon inspection we found that the fan connector plug had melted. We called it a night for racing and rigged it up straight onto the battery to get me home.
Have ordered a new DT plug which should fix the issue as we just had a cheap narva plug on it.
Pretty happy with how it feels at 25psi. 1st gear is a nightmare for traction so I'll have to play around with the alignment and tyre pressures and probably need to do a bit bigger skid to warm them up.
Here's a few vids from the night.
  • Like 2
  • 3 weeks later...
  • 3 weeks later...
Another mint night out at roll racing last night. Car performed absolutely on point all night, not one issue now. Prepped the car when I got back on yesterday. Drained catch can, fixed my shifter bracket, pumped my tyres up, finally hooked my boost gauge up and gave the car a bit of a tidy up. Went more prepared this time with a bottle of oil and an empty bottle to drain my catch can into at the track. I had 10 runs all night, dropped the can before eliminations, after 6 runs and about 250-500mL of liquid came out. Which is good compared to the last time i had it overflowing. Heres some videos for everyone.
  • Like 2
42 minutes ago, Russdmuss said:
Being following your build for a while, such a great build.
Seen you out at roll racing last night. It hooks up really well, you had some good races.
Cheers mate, really happy with her last night. Cant wait to put some boost in :D
Few pics from roll racing on the weekend for you guys!
Have ordered my 3rd fuel pump to chuck into the  surge tank. Should fuel the setup at max power no worries now.
To do list is install the pump this weekend and wire it up. Hopefully take the car for an alignment saturday some time. Then if all is well we'll chuck it on the hub dyno the following saturday. Also gotta get a button for push to pass on the street if i need it. 30psi or so. Then setup the low/hi boost switch for 25psi and 40psi.
Thaat should keep me happy for a while ?
  • Like 3
Finally got her on the hubber today! Put my 3rd fuel pump into the surge tank last night and upgraded the alternator cable.
Car is on point! Ran out of turbo at 35psi making a whopping 1021hp! Can't wait to dial her in and see what she's got down the 1/4.
  • Like 7
  • 3 weeks later...
Not much has been happening with her lately. We've made a new catch can as the old one was restricting it and pushing a bit of oil into it at roll racing. Was having to drain it before eliminations, now with the new one we went the whole night without draining it. Got home and there was about 150-200mL of fuel/oil which is a lot better than what it was considering it still has 2x1.2 feeds into the head. Next time we pull the motor down ill be blocking the center feed which will hopefully sort it out completely.
Car has been going well at roll racing. We've found the limit of the tyres at around 28psi boost. Timed with the dragy have been running a 4.1 100-200km/h time out there which is still half a second off the quickest RWD car out there. Getting out of the hole is the hardest part being restricted to only being able to go 40-50% throttle until hi gear to avoid wheel spin. Now looking into going 3.7 diff gears which should allow us to get off the mark a bit better. Hopefully try and get that done before next roll racing. Also new tyres are needed and I also want to get some coilovers for the front to raise it up as she is sitting very low with the new setup. Raising it should help transfer the weight onto the rear wheels a bit better.
We will probably end up going to a 275/60 MT which will open up a whole other can of worms. Will have to do a bit of modding back there to get the 28" tyre to fit as it will be very snug. In the meantime I'm going to get some smaller spacers and pull a tad bit more camber out in the back to try and get that little bit extra contact on the tyre.
  • Like 7
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
