8 hours ago, admS15 said:
Are you using the anti lag/launch off the line or just doing it manually?
Yeah got anti lag on set at 4k. Can't do WOT launch though haha. Think I'm launching with 10 or 12 pound boost. That 11.7 run was at about 3/4 throttle in first then WOT in 2nd.
Just a small update... Finally got my windows tinted. Nice 15% on it, looks heaps better and now my right arm won't get as much of a tan ? Also got a set of Work Emotion CR-Kai's in 18x8.5 +35 fronts and 18x9.5 +38 rears. 100x better than my other wheels. Just need to get some good rubber on em! Any recommendations? Thinking about just going RS3s again as they've performed really well. 245 fronts and 265 rear should look good on them :)
Will look a pulling my head off and get it all reco'd with the new cams, studs, gasket etc at tax time. Still not sure if I wanna give the nistune another chance or just go to a link g4 straight up. The idle hunting and stalling is really pissing me off and also cold start is a bitch now.
  • Like 1
5 hours ago, vxsr33 said:
Damn that looks mint.
Only thing i would do is swap the tailights for the stock ones.
Cheers man! Yeah I have a set of stock tail lights at home but I'm too lazy to pull them out and change them ?
Probably one of my favourite pics of the car!
Have decided I'm going to try a set of Nankang NS-2R's on the 18's in a 265/35r18. Might put the 235 proxes that are on the rear up front for now and if the Nankang's are good ill throw a set up front in 235 or 245.
Got the Nankang NS-2Rs put on the rear. Fills the guards way better. I could only get the 180 treadwear rating ones for some reason.... They are f**ked when theyre cold, so slippery. Seem to be ok when theyre warm. Still haven't tested them properly yet though. Will probably go out to willowbank on Wednesday for a run with my mate who just got his 33 tuned.
  • Like 2
Saw the video on Facebook today, sounded awesome! Looks much better with the new wheels too.
I ended up ordering the subframe and front and rear diff bushings like you did  with yours the other day - have a mate at a parts shop who got it for half price. What ended up happening with your bushes that fvcked out for the front of the diff, did you find out why that happened?
Yeah cheers man, really happy with how it went and the new look!
Nfi with the front bushes, I need to check them to see if they haven't done it again. If it has i'll be going to solid front bushes..
On another note I'm still losing slight traction in 2nd. I'm gonna take it down to get 0.5-1 degree of camber out of the rear which should hopefully allow me to hook up a bit better. Ill take it down the strip after winternats and see how she goes!
3 hours ago, klutched said:
So I just checked my pinion bushes anddddd it's done the same thing... Looks like ill have to get some solid bushes in there...
Ugghh that's disappointing. I wonder if it would be worthwhile adding a washer to the top side too?
I'm not sure, definitely something wrong as the same thing happened on both sets.
I have ordered a diff bush kit from Gktech and also a poly gearbox mount. Hopefully get it all in before Roll Racing this Saturday.
When you pulled the original factory bushes out, what condition where they in?
They were fine, I'm thinking it could be because I put the Nismo LSD in? All the hopping and shit from it could have cause it.
I reckon they should be able to take that for a while longer. There only a month or two old aren't they. Maybe start a new thread about it and see if others that have experienced similar can steer you in the right direction of the cause. Cheers.
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
