Brembo front brakes off a Porsche 996 TT with dba slotted rotors come with adapter to fit R32 GT-R.
Swapped back to stock brakes when I sold my GTR so these have been sitting in my garage for years so will need some TLC
$1000 ONO. Can deliver free to Sunshine Coast or Brisbane if timing is right.
https://www.sau.com.au/forums/topic/464337-brembo-brake-upgrade-r32-gtr/
5928 is the GTR brembo size, 324mm, but OP can confirm. Not sure about the adapter because I can't see them in the pics, but I run the same discs and calipers on my race car and I reckon it's a bargain at this price.
Duncan is correct. 324mm
I think they are significantly under what they would usually be priced at, I just want them gone as they have sat under my house for a long time.
Good for the right person who doesn't mind installing new pads and presumably replacing the seals.
  • 3 weeks later...
Are you selling front & rear?
What is the minimum wheel size to run these brakes?
Just the front, stock rear brakes where used with this setup without issues.
A few different sets of 17" rims where used with them without issue, I don't own the car anymore so I cant comment further.
  • 2 months later...
Sorry been away for a few months - replying to PM's now.
Another member pointed out rebuild parts that should work here:  http://www.racingbrake.com/SearchResults.asp?Search=BP-406&Extensive_Search=Y
PM sent
  • 3 months later...
  • 4 weeks later...
Hey Duncan,
Were this more than enough for you? Without changing the rear and just the fronts? Braking strength good?
Im still on Stock 32's non Brembo and am looking at an upgrade - was thinking of 350mm evo Brembo's front and rear but seem overkill - just want to see your POV...
Thanks!
^ Pads easy to find? Good pads?
I'm very happy with my similar setup on the race car, I've run up to 1hr enduro races on them and targas etc with no issues. These are a bargain at the posted price even if they need a reco
  • Like 1
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
