I've always been a person who likes to have their tyres at the right PSI. However I never actually know what is the "right" PSI. Looking at the tyres gives you a MAX pressure number. This can vary from brand to brand and sizes. However most tyre places seem to under inflate the tyres in my view. Like putting in 26PSI when the max is 44PSI. I never go the max, but I would go maybe 38 to 40.
Am I really supposed to go on the PSI listed inside the door, even though I don't have the same rims or tyres that came with the car?
I occurred to me that maybe all these years I've been putting in too much air. Now that I got some new tyres, I think I need to fess up and say, I'm just confused now if I've ever been doing things right.
One of my current Bridgestones is showing wear in the middle of the tyre so maybe I've had it pumped up too much. I normally go 41PSI as I found out you'd lose 1PSI when disconnecting the hose. So was running in effect 40PSI in the rears, but now think due to that wear patch maybe it was too high. I do like them firm though.
Wear in the middle is a good indicator it's overinflated (and that will vary between tyres and sidewall heights)
Higher pressures can carry more load, will use less fuel and will handle better. Downside is they can be harsher (but frankly, if you are running 45 or lower profile tyres you've already decided to accept a harsher ride).
In my experience tyre shops and mechanics tend to go for a low pressure (30 or lower) and I honestly don't have any idea why
Maybe it's speed. Quicker to fill it up to a lower pressure and thus time is money sort of thing? I have no idea why they under inflate either, but I've always known they have for some reason.
These tyres were used when I got them, so not too sure it was all me with the higher pressure, but I think for this next set I'll go lower. Instead of 40 maybe start at 36/37 and see how that goes.
I like them high, but don't want to wreck the tyres.
...to get more grip perhaps?
It's probably not as extreme as with semis but I'm pretty sure that the same street tyre will grip better at 32psi than 42psi...?
interesting idea, I'd love to see a back to back test. yes lower pressure will give you more rubber on the road but I'm not certain that translates directly to extra grip because each contact patch will move more relative to the wheel
Mythbusters proved it
http://actiontyres.worldsecuresystems.com/latest-news/effect-of-tyre-pressure-on-fuel-consumption
FWIW I run 34 all around on 40 profile tyres, and at the moment have a really good alignment (for the first time in my life, i.e. no inner camber wear) and tyres are wearing evenly
No source, but I wasalways under the impression that higher pressure is better for fuel economy, lower pressure for grip, obviously to a point like so:
As usual, it's more complicated than it seems. 32psi is for putting around town with your family. I recommend 36psi for daily drivers, I run 38-40 depending on season/weather/tyre.
Cheap tyres generally need at least 40psi to get some grip out of it.
My old mate a tyre guy and owner of his own tyre shop. I always bug him with questions which he doesn't like to give up his 40yrs experience......
Now he said not many people do it right dealership like soft gets a better sale softer ride.
Tyres say max.....
Door frame label says complete opposite.....
So on so on
Best is get a smooth flat ground dark as well. Now put some talcum powder on the ground in a line wide as ya finger but longer then ya tyre now push your car over the line keep rolling it 360 degrees so it makes a tyre print.
Now according to that print you would be able to tell if you need more or less you may need to do a few prints.
Remember front to rear will differ
Hope this help i might try make a video (if we have time ) with him helping me its a bit of an old art thats now days is forgotten.
Tyres say max.....
So on so on
Sounds too damn complicated. How about you just tell us what you use on your tires? lol
Unfortunately that would not work on your car unless you have a landcruiser with BFGs 265/65 r17 lol BTW dont own a skyline [emoji26] but i wish getting there.....
But yes all it takes is one person to do it then free 4 all
Example : R33 GT-R with Pirelli P Zero with this size ....______..... 36psi
Or with Proxes R888 size .._____.. 38psi
Its very rewarding at the end ;)
Edited by pol1on1
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
