I've always been a person who likes to have their tyres at the right PSI. However I never actually know what is the "right" PSI. Looking at the tyres gives you a MAX pressure number. This can vary from brand to brand and sizes. However most tyre places seem to under inflate the tyres in my view. Like putting in 26PSI when the max is 44PSI. I never go the max, but I would go maybe 38 to 40.
Am I really supposed to go on the PSI listed inside the door, even though I don't have the same rims or tyres that came with the car?
I occurred to me that maybe all these years I've been putting in too much air. Now that I got some new tyres, I think I need to fess up and say, I'm just confused now if I've ever been doing things right.
One of my current Bridgestones is showing wear in the middle of the tyre so maybe I've had it pumped up too much. I normally go 41PSI as I found out you'd lose 1PSI when disconnecting the hose. So was running in effect 40PSI in the rears, but now think due to that wear patch maybe it was too high. I do like them firm though.
Wear in the middle is a good indicator it's overinflated (and that will vary between tyres and sidewall heights)
Higher pressures can carry more load, will use less fuel and will handle better. Downside is they can be harsher (but frankly, if you are running 45 or lower profile tyres you've already decided to accept a harsher ride).
In my experience tyre shops and mechanics tend to go for a low pressure (30 or lower) and I honestly don't have any idea why
Maybe it's speed. Quicker to fill it up to a lower pressure and thus time is money sort of thing? I have no idea why they under inflate either, but I've always known they have for some reason.
These tyres were used when I got them, so not too sure it was all me with the higher pressure, but I think for this next set I'll go lower. Instead of 40 maybe start at 36/37 and see how that goes.
I like them high, but don't want to wreck the tyres.
...to get more grip perhaps?
It's probably not as extreme as with semis but I'm pretty sure that the same street tyre will grip better at 32psi than 42psi...?
interesting idea, I'd love to see a back to back test. yes lower pressure will give you more rubber on the road but I'm not certain that translates directly to extra grip because each contact patch will move more relative to the wheel
Mythbusters proved it
http://actiontyres.worldsecuresystems.com/latest-news/effect-of-tyre-pressure-on-fuel-consumption
FWIW I run 34 all around on 40 profile tyres, and at the moment have a really good alignment (for the first time in my life, i.e. no inner camber wear) and tyres are wearing evenly
No source, but I wasalways under the impression that higher pressure is better for fuel economy, lower pressure for grip, obviously to a point like so:
As usual, it's more complicated than it seems. 32psi is for putting around town with your family. I recommend 36psi for daily drivers, I run 38-40 depending on season/weather/tyre.
Cheap tyres generally need at least 40psi to get some grip out of it.
My old mate a tyre guy and owner of his own tyre shop. I always bug him with questions which he doesn't like to give up his 40yrs experience......
Now he said not many people do it right dealership like soft gets a better sale softer ride.
Tyres say max.....
Door frame label says complete opposite.....
So on so on
Best is get a smooth flat ground dark as well. Now put some talcum powder on the ground in a line wide as ya finger but longer then ya tyre now push your car over the line keep rolling it 360 degrees so it makes a tyre print.
Now according to that print you would be able to tell if you need more or less you may need to do a few prints.
Remember front to rear will differ
Hope this help i might try make a video (if we have time ) with him helping me its a bit of an old art thats now days is forgotten.
Tyres say max.....
So on so on
Sounds too damn complicated. How about you just tell us what you use on your tires? lol
Unfortunately that would not work on your car unless you have a landcruiser with BFGs 265/65 r17 lol BTW dont own a skyline [emoji26] but i wish getting there.....
But yes all it takes is one person to do it then free 4 all
Example : R33 GT-R with Pirelli P Zero with this size ....______..... 36psi
Or with Proxes R888 size .._____.. 38psi
Its very rewarding at the end ;)
Edited by pol1on1
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 馃ぃ And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 馃お
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
