On 4/22/2016 at 2:33 PM, tridentt150v said:
I always wondered who bought second hand euro's......I think you should try a Peugeot or Fiat next!!!
Actually, no, don't.........be cheaper to find a brick wall and start hitting your head against it :woot:
Alfa Romeo are known for their reliability, right?
I now have a MiTo, not joking.
I looked at an Abarth 500, Citroen DS3 DStyle, DS4 DSport and ended up going with the MiTo because it was the cheapest with similar Ks and they were all fun. Oddly the DS3 was the most toy like, stupid fun to drive. Trying to convince my brother to get a DSport version.
Also there appears to be at least one good used car dealer however I will reserve judgment until all our dealings are complete but so far he has
Agreed on a trade in for the Volvo sight unseen.
Stayed late on a weekend so I could test drive  a few of their cars with my wife while he and my dad entertained our 3yo.
Put respraying the bonnet in writing if stone chip touch-ups were not satisfactory.
Offered to move his Dr appointment so I could take delivery late in the day.
Was dissatisfied with how the bonnet came up but wanted me to have the MiTo for a couple of weeks to find any issues I might have so they can be resolved all at once.
  • Like 1
MiTo is down at Mauceri Motors for a major service including timing belt etc.
The timing belt should have been changed almost 5 years ago (!) as it's a 120000KM or 4 years job.
Not that it hasn't been running fine so far but I'd rather get preventative maintenance.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
