Hi all just bought my Stagea (Stagea-C34-Autech-260RS-WGNC34) wanted one for too many years, stepping out of a BMW X54.6IS worked,
I have uploaded a gallery of images.
So far I have just replaced the Japanese head unit with motorised Clarion DVD iPod Reverse camera,amp & aub etc...
Many many mods from Japan major step is to get the power turned back on... MINE"S ECU Apexi Exhaust Sards hi-flow cat, Garrett turbos, fuel rail, injectors, HKS ignition,G-Racing coil overs, alloy front upper arms, Alloy wheel hubs, 2 piece VOLK RAYS, so much more I'm still finding...
Need help on unleashing he power... I'm in Newcastle & need a good tuner, I've had a complete inspection at the mechanics & everything is spot on but is is under powered.
Any advice would be very welcome or a contact for someone that can turn on the tunes or re-tune the MINE"S...
Edited by TMLP
  • Like 1
https://www.sau.com.au/forums/topic/464394-new-import-how-to-tune-a-mines-ecu/
x2
cant be tuned, dosnt suit straya fuel anyway.
buy a nistune and 2x z32 afms
$500 + $500 = $1000
or spend a little more and get a plug and play haltech and don't need to buy afms
$1800
Edited by GH05T
x2
$500 + $500 = $1000
$1800
any reason you say HALTECH? as I just spent $2500 replacing The Japanese Head unit so a bit for a ECU is well worth it...
If you already have z32s then nistune will be much cheaper. and a good option in its own right too, can still go flex fuel with the new ones.
I prefer haltech with no afms for several reasons but just have a bit of a search for the pros and cons of each ecu.
but tbh if you have already spent cash on z32s I would probably just spend $500 get a nistune and get a tune done.
Congrats on the autech :D I picked one up in March.
Just out of curiosity, I assume its fine, but is there any detriment or benefit to running the z32 afms with haltech?
There is a school of thought that says AFMs are more accurate than MAP sensors but my own thinking is that MAP sensors are closer to the action ... but I am open to being proved wrong. I haven't seen any back to back comparisons.
Well it's to be sorted out next week. Took a while to work out what to do & thanks for the advice.
Jezz at DVS Tuning gets the car on Monday for...
-walbro 255 fuel pump
-725cc injectors
-haltech ECU Dyno tuned with boost solenoid
-upgraded camshafts
-adjustable cam gears
-100k service kit (am I over servicing? 82K on the clock) including water pump
-rocker cover gasket kit
- oil catch can
Time for power...
Edited by TMLP
-725cc injectors
-upgraded camshafts
- oil catch can
Time for power...
Always worth doing the cam belt on a new purchase - you don't know how accurate the km on the clock are.
Cam/timing belt being done as part of the 100k service to be safe.
Anyone have similar mods on an RB26 DETT - DET or RB25? If so what sort of power do you get & what do you think I will get?
Thanks Shaun.....
I got 270rwkw
r32 stock engine stock turbos
halltech platinum pro 1bar boost controlled by an electronic solenoid
without the cam upgrade and running out of injectors so you should se somewhere between that and a bit higher.
your turbos will run out before 300 I would say
Edited by GH05T
well yeah, greatly.
what boost are you planning to run?
what cams are you going for?
Devs will be able to give you a much better answer I can cos I don't know.
depends what runs out first, boost/fuel/....stock bottom end
Edited by GH05T
I will go with what the mechanic recommends as I'm no expert.
But I do not want to destroy the engine as the car is almost NEW condition inside & out. I was very lucky to come across it.
Everyone wants over 300KW & a 10sec car, here's hoping/dreaming.
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
