Let me start with this is my first RB I've owned, I'm used to XR6T's.
Long story short, when I run 14psi it feels considerably less slower ( especially in 2nd gear ) then it does running 8psi or so.
Anyone care to explain why? I know that it's not tuned for it but didn't think it would have such a big effect.
https://www.sau.com.au/forums/topic/464420-car-is-slower-on-14psi-then/
If so that is your problem. You're forcing more air into the engine. Chances are you need to adjust the air to fuel ratio in each cylinder accordingly. Too much air, not enough fuel, thats my guess.
Nope.
Too much fuel.
The stock ecu chucks in heaps of fuel and pulls timing with higher boost. Also referred to as rich and retarded.
Presumably you're talking about a 33..
14 is too high for the stock ecu, likely will blow the stock turbo pretty quick too.
In stock form anything over 12 is pushing your luck. 10 is generally about as high as safe levels go.
each car will vary in exact levels before its starts to fail.
Whoever told you 14 is a cowboy and you should disregard everything they have ever said. unless you want to just crank shit up till it blows and have your car off the road more often than on it.
Anyway, you have a lot of researching to do, so get to it =) its all here on SAU. Reading a few threads would have told you all this =)
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
