people give the R33 gtst sh&t saying it handles like a boat; I disagree. It handles great, just not in stock form. Then again, a lot of cars don't.
Some stuff I've got for sale, for an R33 but I believe most/all will fit r34 - pls check for yourself though to confirm. All available for pickup/delivery in Brisbane, or postage as listed.
R33 a-pillar braces. Handmade in my workshop so don't expect production-line welds and finish; they are neat enough, fairly light and strong as sh&t though, and if you don't notice the front end feeling a lot more solid on the road over 100kph I'll be very surprised, I found a huge difference once fitted. $100 the pair, $15 posted anywhere in Oz.
TEIN medium S-Tech springs. These drop the car by about 30mm, and are around a 4.2kg spring rate? from memory anyway, exact rates on the Tein JP website. Ok, these are as close to brand new as you can get; bought them when I thought my bc coilovers were on the way out. Bought these tein springs and put them and a set of shocks in, and found the issue was the same and nothing wrong with the bc's (product plug for bc's, good item) and so these springs came straight back out, and have sat in the garage for the last 18 months being kept for when I might need them again. BC's still going strong, so if you want a set of top-quality springs new without the new pricetag, here they are, still in original Tein box.
Link to counterfeit Tein spring id'ing, these are genuine not copies. https://thecounterfeitreport.com/product/336/Tein-S.-Tech-Springs.html
here's the cheapest price I could find
http://www.ebay.com.au/itm/TEIN-S-Tech-Springs-medium-Nissan-skyline-Ecr33-Gtst-/151723212392?hash=item2353687e68:m:m8tmNJcZc0sCVq7xzJTFytA
so, I'll do $350 for the set of 4, and $20 posted anywhere in Oz except NT and WA.
Cusco castor-rod brace. Genuine item not a copy, in excellent condition, just has usual scuffs/marks from being fitted to car. This is cheapest price I could see
http://www.ebay.com.au/itm/CUSCO-TENSION-ROD-BAR-BRACE-SKYLINE-R33-ECR33-R34-ER34-GTST-RB25DET-RB25DE-RB25-/141646100094?hash=item20fac3f67e:m:mBRbPtLm42OS3HSHxWzM4Sg
so, $90, plus $12 posted anywhere in Oz except NT and WA.
also
genuine HKS SSQV recirc adapter, 29mm hose size. Brand new, still in box as per pic. I found the 25mm adapter fitted to the other end of the hose so didn't end up using this 29mm one.
$15, plus $7 posted anywhere in Oz.
also
2x stock R33 wastegate actuators, just have mounting holes elongated to work with Hypergear hiflow turbos, will still work just fine with stock turbos. $15 each.
Gizzmo IBC-R electronic boost controller, options of 6 boost presets, and rpm setting. Guaranteed in good working order with user manual, just that the wires have pulled out of the back of the plug that plugs into control unit. Either track down some square-end wiring plugs or just call Ray at gizmo and buy another plug kit, and you got yourself an electronic boost controller cheap. $100, plus $10 posted anywhere in Oz. And I do mean guaranteed working, I wouldn't sell it if it was no longer working.
other stuff
- set of 6 stock R33 injectors, $40.
- 2x R33 series 2 engine mounts, rubber solid as, no cracks/splits, $25. Sriously in good cond and perfectly usable, I just put Nismo mounts in trying to eliminate drivetrain 'slush' as I have auto trans.
- series 2 CAS. Working fine, I replaced CAS when troubleshooting idle issue which turned out to be afm. You're welcome to test before buying if in Brisbane. $80.
By all means reply to thread but also PM me pls so I can get back to you sharpish. Any q's on anything just let me know.
  • Like 1
https://www.sau.com.au/forums/topic/464446-grand-sale-grand-sale-megalo-r33/
a-pillar braces, recirc adapter and castwizzle-brace sold.
Also found in my garage
- 1x set of subframe aluminium lock collars, black. Look just like the million other pics of subframe collars, except one of the upper collars has a slightly ground-away section where I was trying to make it seat in better against the OEM rubber before I realised it would make no difference so gave up, so is only done to one of the pieces. $30 plus $5 postage, happy to post up a pic if anyone keen.
- R200 ABS diff off r33 gtst, 4.1 gears. Long-nose? has abs sensor at front near tailshaft. $100 pickup or deliver in Brisbane, too heavy to post.
  • 5 months later...
trash or treasure, a bargain or an insult to your wallet? you decide.
All parts for R33 gtst.
Subframe collars - have 2 sets, one aluminium solid type, the other Superpro urethane (seem to be missing 1 ring, as soon as I find the other one in my garage, will sell as a full set). Marks etc as pictured, both still in good order and very serviceable (aluminium ones hardly used, superpro ones have about 3 -4 years on them) $25 a set.
Superpro steering rack bushes, about the same amount of use 3-4 years, still in very good order. $20.
Genuine Nissan tailshaft centre bearing. This is effectively brand new, but - fitted this bearing, only to find an issue with the tailshaft itself, so had to swap tailshafts. As this was brand new and they cost $160+ I pulled it off and in trying to do so without damaging the rubber casing, one centre flange got bent up as pictured. If you straighten this out so it doesn't rub, it will be as good as new, but, price reflects this damage. $50 neg.
Which leads me to - 1x tailshaft flange and front section, both still in good working order, issue was with rear section. These might be handy if making a custom tailshaft...? $20 neg anyway.
1x R33 actuator, $10.
pickup on Brisbane northside or can post anywhere in Oz (tailshaft excepted).
  • 8 months later...
all still available as above, plus have found the missing piece for the superpro subframe bushes so now is a full set.
Also have
- stock rear strut brace for R33GTST, $40, in VGC - comes apart into smaller pieces so can post easy enough.
- set of 4 Bridgestone Potenza RE003 245/45/17 tyres. 2 are in extremely good condition, done just on 3000 k's, other 2 are still in good order but have done just over 6000 k's. According to Bridgestone these have 7.1mm tread depth new, and they still have 5.6mm and 6.33mm depth respectively, so heaps of life left in them. They don't have enough dry grip in them for my liking but they do have a lot of wet grip, and for the price, a good dry tyre too. After $160 for the really good 2, and $120 for good 2, or can do a better deal for all 4.
  • 1 month later...
BNE - rb25det to suit rebuild
Rb25det bottom end out of R33 Skyline - block is in good order, crank is good but superficial scuffing to no.3 rod journal where rod spun a bearing - only shallow marking so will be fine for engine rebuild. Have the stock rods, and 4x stock pistons (have used the other 2), and sump.
Apart from oil pump which is yours if you want it, this is just the parts listed, no balancer, manifolds etc.
Had bought this to do an engine rebuild but ended up rebuilding the engine already in the car.
Not really keen on shipping, prefer local buyer in Brisbane - $150.
  • 1 month later...
GK Tech tie rod ends, as new
yo...Bought a set of GK Tech spherical bearing tie rod ends, as shown here
https://www.gktech.com/high-misalignment-64-degrees-tie-rod-ends-12mm-14mm.html
As everyone is no doubt aware spherical bearings can transmit a lot more NVH, and I found I didn't personally like the feel of them in the tie rod ends for a street car, I prefer a ball joint. So, after only being on the car for 167km's (then changed to ZSS ends as per log book), we have an almost new full kit for sale. The current GK Tech kit doesn't have holes in the ends of the kingpin for a split-pin retainer so I have drilled this in, to allow the extra security of having a split-pin fitted top and bottom. As it notes in the GK Tech link, you need to cut down your stock tie rods too to fit these, so included is a set of rods already cut to the right length (note if you cut your rods, it only leaves about 8mm of thread engagement if you ever decide to go back to a stock-type balljoint). One rod is genuine Nissan, the other is Roadsafe - both 12-18 months old and easily 5+ years left in them.
Selling the tie-rod end kit and the 2x tie rods as a set, $150 posted across Oz .($160 WA and NT)
20170319_125943.thumb.jpg.b4938b5c25cb361f0b7bfd8ab7fa6722.jpg20170319_125951.thumb.jpg.b1f8aed736f1d077382524cf06f34f14.jpg
  • 6 months later...
strutbrace and tyres were sold. Other bargains still available.
Also have a stainless steel intake pipe for R33/34 - has 2x BOV return nipples for those custom setups. $75 +postage.
  • 1 month later...
