Hi all,
Brand new crank angle sensor - Mitsubishi ones to suit RB20, non Neo 25 and 26.
Asking $350.
A set of factory coilpacks for RB20, s1 RB25 and 32/33 RB26.
Working prior to removal.
Asking $25.
Factory RB cam gears.
Asking $0.
Bosch 044, working prior to removal and has been in plastic bag since.
Asking $0.
R33 GTR factory tie rod and ends, in good condition joints and ends are smooth.
Asking $0.
Standard rotors to suit Brembo equipped GTR's.
28.5mm thickness, could use it to roll the car around.
Asking $25.
Location is Wantirna South, SE Suburbs Melbourne. Can be contacted by PM on here if you have questions or such.
Cheers
Grant
would you consider separating the wheels from the tires?
they are good but simply will not fit under my car :P
Josh will be very jealous if u get these Glyn ;)
Update on what's sold
Panasport wheels.
Cusco brake master stopper.
Everything else is still available.
Cheers
Grant
  • 3 weeks later...
  • 3 weeks later...
Bump-pump. And prices are negotiable on all available items!
Don't be shy.
What this guy said.
And above guy is motivated to sell! Chuck offers at your wildest dreams!
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
