Hi guys,
Have done some research on SAU and online but haven't come up with a definitive answer yet.
Car details: bog stock except turbo back exhaust, aftermarket bov, turbosmart boost tee @ 8 psi, brand new yellow jackets,
Milliseconds after hitting boost it feels like I've hit a brick wall (like foot is off the accelerator when it physically isn't). I'll try to accelerate again but instead it's an intermittent violent herky jerky motion as if I'm repeatedly on and off the accelerator. If I attempt to smoothly apply throttle without boost it may pick up again. Sometimes I will come to a stop and car will stall. While car is decelerating I can see the boost guage fluctuate according to the pressure I'm applying to the accelerator. Though not as pronounced, the engine sometimes will also cut out intermittently after a warm start on idle and stall...doesn't happen on a cold start. The other night also had trouble starting the engine from warm. It would crank fine but would only fire for a second then stall. Tried starting repeatedly and got it to idle fine after about half an hour of attempting.
Thought it could've been coilpacks so I got brand new ones along with plugs and dropped them in but same issue.
I've recently cleaned the AAC valve and AFM in the past month.
I've read that it could be the cam/crank angle sensor? Possible timing issue - RnR? Fuel cutting?
Any advice appreciated. Thanks.
https://www.sau.com.au/forums/topic/464480-rb25det-intermittent-power-loss/
Coils were the obvious choice. Next most obvious is a dodgy solder point on the AFM. You might be able to fix that yourself. Have a search for howtos.
Faling CAS is possible, but doesn't often give the symptoms you report. Failing fuel pump could.
It is not R&R unless someone has advanced your CAS all the way.
Thanks for the responses. Last time I cleaned the AFM I had a look at the soldering on the joints and it seemed fine. Maybe the actual measuring element is playing up.
Will be trying another AFM. Is the R34 AFM interchangable with the S2 ECR33? The part number for the S2 ECR33 AFM is 22680-31U05 and the website says it is compatible with R34 as well (http://www.rhdjapan.com/nissan-oem-maf-mass-air-flow.html). However I'm looking to buy an AFM with the part number 22680-31U00 since it is cheaper..I'm thinking this is the R34 GTT one. Can anyone confirm before I hit the buy button?
just to be sure, when you say 8psi, that is on an aftermarket boost gauge right? and not the stock gauge. Stock one is not psi.
If you cant boost properly how do you know its set at 8?
Was it all working fine then suddenly one day this started? or Did it gradually get worse over time?
what was the last thing you did before this happened?
  • Like 1
Yep 8psi as seen on an aftermarket boost gauge. I've since had to remove it due to it being a defect but when I had it on it did read 8 at WOT.
Prior to the issue the car was running fine and it read 8 psi.
Just happened suddenly. I remember first time I experienced it.. I was at a red light and gave it a decent launch and the car got all herky jerky on me. Didn't know what it was but I cleaned the afm with CRC but didn't resolve the issue. It has since gotten worse over time. I don't remember doing anything major prior to the start of the problem.
Also, just as a precaution I checked the coil packs and plugs. I found one of the coil packs didn't have a spring in it as seen through the hole which sits on the plug. I thought this was the problem. Spark plugs didn't look to have any abnormal wear. So I bought brand new YJs but issue still persists.
The reason I went with YJs is for the post sale support.
I have only ever heard bad things about their post sale support, but if thats what you want.... Would be nice if you can report back with positive feedback on the YJ's eventually though.
try replacing the afm ( borrow before buy :) ), double check all piping and connections, remove boost T and just run wastgeate actuator pressure.
Just starting with the basics and cheap options. hope you find the problem soon.
Not too sure how this turned into a flaming thread.. Didn't ask for anyone's opinion on the coil packs I bought.
Anyway I got a working afm and it has seemed to fix the problem. Thanks to the guys who provided feedback about my problem.
  • Like 1
Hopefully when your coil packs die they're still in the warranty period so you get a brand new set (brand name clearly not mentioned, so vendors don't has a sads).
I had two coils die out of warranty, bought two new ones. Kept missing firing gave up, bought Splitfire coil packs and they're still running like a cut snake till this day, even with added dwell because I live life on the edge.
#keepdosing
  • Like 2
#keepdosing
Ffs u blokes r all missing the point here. Who gives a shit what brand coils he bought. A dose pipe will cure all misfire issues. That is my new recommendation for these type of threads. Should of bought a dose pipe.That is all.
Ahh very true, excuse my ignorance and lack of knowledge.
Yes a dose pipe will fix the issue and introduce good backfires on deceleration like a bawse!
Suuuuuutututu pop flame brap lol
  • Like 1
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
