I'm thinking about selling my 4" titanium cat back exhaust to suit r32 GTR
In very very good condition, very light, sounds amazing !
Previous owner said it was an amuse exhaust but can't see any markings
I'm in 2 minds about selling but if I get the price I want Ild let it go,
Also have a brand new 4" flange to suit exhaust so you can weld it to ur cat and everything bolts up 100%
Asking $1700, located in Sydney and can help with postage if need be (wrap it up and package it etc)
Edited by SiR_RB
  • Like 2
Pics of it on the car? 4inch inner or outer diameter?
considering titanium exhausts r only 1 or 2mm thick it would make zero difference
  • Like 1
Looks good but most jap titanium exhaust that I have seen including my own one have a lot more crab weld sections in the bends. Are you sure it's a jap exhaust?
I really need a 4" exhaust. How high does it sit up?
If i didnt already have a 3.5" Ti exhaust, i would snap this up in a heart beat!!!
I would say it would be pretty loud, as my one has 2 mufflers and still sounds loud and angry
  • 4 weeks later...
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
