So much garbage on here once again with people putting shit on the power fc!
If anyone had a bad experience with a power fc it's because there tuner is SHIT.
It's an ECU it does what it's told
You've missed the point totally here mate.
Second hand FC = $700 with heckers hand controller
Nismo AFM's = $700
Thats $1400, more if you want to buy the ECU new.
Yes it will do the job. However, if you want to do something basic like a Flex tune you cant do it.
OR you could buy something like a plug in Link G4 for a few hundred more and be able to do heaps more with it.
There is "cheap" and there is "value". They are not the same sometimes. A Power FC in 2016 is not a "value" option.
You don't buy a box of rotten banana's for $1. Why? You can't do anything with the bloody things!
  • Like 4
So Nistune is good with big injectors? A mate had trouble with his 330rwkw SR setup and tuner kept blaming Nistune and the 2000cc injectors (think they were 2000s)
No idea if it was fact or just blaming as it was the easiest escape goat. He gave up on cars and being raped by all the Sydney experts so sold the car.
$700 for a second hand D-Jetro with all accessories.... Pretty good value I recon.
What does it cost to intsall (if paying a workshop to pull off intake plenum and put the MAP sensors where they should be)?
LOL.. did you see my forsale thread on Driftsales?
Sold it in 3 days.. got an adaptronic for $650.. win x 10 with $50 for beer
PFC purchase, install and tune was on par with the cost of selling my M84 with the loom and accessories that I didn't need anymore.
And no more T T T T Timing jitter.
If I wanted to keep the haltec or M84 I would have spent another 2k for a crank trigger.
So massive saving and car runs the best it ever has.
And have my $350 Innovate SCG1 looking after boost and AFRs which cuts boost if I go lean, and has a 5V output to supply signal to FC edit software if I want to log it all.
Can't see a problem at all TBH
Edited by XGTRX
Nistune will drive big injectors just fine. I'm not sure that 2000cc injectors count though. They are more like open fire hydrants.
At ~330rwkW that SR20 really didn't need such big injectors. 1400cc hoses would probably have done it. And regardless of what ECU, once you start getting to injectors that size you really need to consider whether staging them makes more sense rather than asking something big and crude to give you a reasonable idle and part throttle cruise as well.
Nismo AFM's = $700
I didn't mention value.
ID 2000's idle and drive 10 times better than Sard 800's. That's on the same car, same ECU and tuner. Actually two cars with very similar setups.
were they CNG injectors? if so.. partly why :)
I have no issues with Nistune with stock to 1250cc injectors on 98 or E85... easiest ECU to get shit to boogie... also TP Cut.. very goose, PowerFC no haz.
I bought my power fc for $400 with controller vs haltech $2100 new without additional additional sensors.
Flex is the ONLY reason i went haltech
+ wideband 02 feedback
+ 2-step, launch
+ flex
+ engine protection
+ no MAF
+ hectic software
+ no need for data logit box shit
+ usb plug wooooo, serial is homo
+ much much more, we'll even included a set of steak knives.
Here's your ID 2000s!
very non linear fuel delivery curve under 1.5 milliseconds which is why ID recommend the 1300cc5c028e760f3690e2b7bb3c46d6dde2c9.jpg
Pull up all the colourful graphs you want mate. I'm talking from sitting in the car driving the bloody thing!
By no means we're they perfect but they were a shitload better than those Sard 800 fluro green tipped nuggets!
Yeah yeah let's not mislead people once again.
you're probably talking about E85 only then which I would then believe you.
because the compressed natural gas injectors do actually atomize really well and you're using a whole lot more Duty cycle being that you are on E85.
I said before PETROL it will not work and they will not work on PETROL and the graph shows that, which is what you do.
you told me you never run on petrol which is why you don't know the difference.
Edited by mr skidz
Sigh.
You have no idea at what point in the life the cars were at.
I do not run the car on petrol much, yes. This was years ago (2010-2011).
Anyway, whatever.
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
