Hey guys I've just bought myself a 98 R34 GTT. Not I found a few little problems with the car but nothing major. The one thing that's got me is the TCS system doesn't seem to work at all???
I've checked the boot for and mods to the ECU , checked the plug and it's plugged in. I'm just lost at what next. The car breaks traction all the time and I have no slip light at all on the dash board. Not even with ign on
All the plugs are plugged up to the butterfly near the TB.
Please any ideas would be greatly appreciated.
Cheers
https://www.sau.com.au/forums/topic/464566-r34-gtt-no-tcs/
The traction control system sucks hard, and just slams the throttle shut. Disabling it is a smart thing to do.
Making it work again is a waste of time.
Get better tyres, drive better.
How much power is it making?
  • Like 1
https://www.sau.com.au/forums/topic/464566-r34-gtt-no-tcs/#findComment-7720929
Cheers
Please check your ECU fault codes and report back. Instructions here, scroll down for a pic of which pins to short: http://www.sau.com.au/forums/topic/266512-reading-nissan-fault-codes-ecu-fault-codes-how-read-them/
I'm currently getting Code 17: ABS-TCS C/U Signal. My TCS never worked since the manual conversion but the ABS is fine.
TCS and SLIP lights are on in the dash too, along with A/T and HICAS because they no longer exist...
Should also state that all it really does is put a 2nd throttle to 60% max throttle. I was able to break traction pretty easily with stock power with the traction control on
Fresh avatar Greg? And yes you're right it's not the most sophisticated system is it...
https://www.sau.com.au/forums/topic/464566-r34-gtt-no-tcs/#findComment-7721294
No. Fault codes are read from the dash light. I don't know what light they use in a 34 - it could be a dedicated CEL. I have my Neo in an R32 so I have the cat light as the CEL.
The best way to read the codes is to use a Consult scanner plugged into the Consult port. More to the point.....the best way to read codes on any of the control units in the car is through the Consult port. If you have a buggered sensor (say the steering angle sensor) then you cannot execute the routine required to put the HICAS CU into diagnostic mode. So you can't find out that you've got a buggered sensor. See the fault in Nissan's logic with the silly dances you have to do to enter diag modes? Scanners cut right through that crap.
Resetting the ECU is a simple case of leaving it without power for a while.
A lot of people actually remove dashbulbs to mask hardware faults that bring up the lights. ABS/TCS, being as optional as they are, would be the biggest candidates.
https://www.sau.com.au/forums/topic/464566-r34-gtt-no-tcs/#findComment-7721756
    • I can ship Nismo floor mats to you: https://www.oemsoko.co.jp/products/nismo-floor-mats-for-skyline-r33-bcnr33-stagea-wgnc34?_pos=1&_sid=9278c1467&_ss=r
    • Here's the link: https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6642/misc/G49?frame_no=WGNC34-137122 What you think about it? The same product i found on nengun: https://www.nengun.com/oem/parts/40567/MiPwn5qAMfCfmpxHNDnwn5q9MDAx8J-QiW9sZC1qcC0xMTAtRzQ5LS0wMDE/Floor+Carpet+%2F+Mat+2/0688339eba149c19 Bot i have spoken to 😅 ensured me, that mats are 100% original, oem product. I have my doubts. I also heard what you mentioned, that nengun often offers items that are actual not available... On the other hand mats i found on japanese yahoo or ebay are in poor condition and still quite expensive so i'd rather wait for some better offers. My location - Poland. We literaly don't have ANY market for used Stagea parts so need to search outside Europe.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
