Hi Guys
Cleaning out the garage so i have a few things for sale
- 20mm bolt on spacers, 5 stud 114.3 m12x1.25 - $70
- 30mm bolt on spacers, 5 stud 114.3 m12x1.25 - $70
- D1Spec steering wheel quick release hub - $65
- R34 series 1 climate control unit (has crack on the top as per photo) - $50
- R34 GTT rear seat, good condition, could do with a steam clean - $40
- R34 GTT Auto gearbox with torque convertor, has shift kit and high stall convertor in it, good condition - $200
- R34 GTT shifter assembly, good condition with gear knob - $80
- 1Gauge digital gauge display with data logging, sensors etc - $350 info here http://1gauge.com.au/store.php
- Eanon car DVD, tons of features etc - $165
- R33 Manual brake pedal - $40
- R34 Auto Brake Pedal - $20
- R34 GTT auto tailshaft - $50
- R34 GTT clutch master cylinder - $20
File_005.jpegFile_006.jpegFile_004.jpegFile_007.jpegFile_000.jpeg$_35.JPG$_57.JPG1gauge.jpgFile_000(1).jpeggallery_4352_2377_11862.jpg$_3566.JPG
  • 3 weeks later...
Update
- 20mm bolt on spacers, 5 stud 114.3 m12x1.25 - SOLD
- 30mm bolt on spacers, 5 stud 114.3 m12x1.25 - SOLD
- D1Spec steering wheel quick release hub - SOLD
- R34 series 1 climate control unit (has crack on the top as per photo) - SOLD
- Eanon car DVD, tons of features etc - SOLD
- Tall crystal shifter, suite Nissan 5 speeds - SOLD
- R34 GTT engine wiring loom - SOLD
- R34 GTT Starter motor - SOLD
the others are still for sale, prices are negotiable, all reasonable offers considered
The 1gauge comes with 1x pressure sensor and 2x temp sensors, additional sensors can be added
  • 8 months later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
