Hello
I posted before I was having trouble with my car due to a fuel pump going bad.
Changed the fuel pump to a Nismo one, car drives better now, smoother. The car cut offs, the hard to reach 3000rpm problems went away.
But acouple of problems still happens. After hard acceleration sometimes, once or twice a day, the car will have no power(no cutting off), as if time froze. The car will be very slow but wont cut off, after about 5-10 seconds of keeping my foot on the acelerator, the car will drive normally again. Last night when I was doing some good driving, not driving too fast, just driving the car with good aceleration and going into boost sometimes, I came to a light, when it turned green and I acelerated and was shifting into third( was trying to pick up some quick speed aka go fast), the car drove very slowly, I kept pressing the acelerator and the car started jerking for about 3 seconds and than drove normally after that.
Things I have done in the past few months. Back in Nov last year, changed to new spark plugs, changed out old coil packs and wiring harness with known working used ones. I had a bad coil pack and the car wasn't running correctly. Before that there was some weird coil wire set up the previous owner had in the car. I returned it to stock. Car drove great after that.
When the hesitating, car cut off problem happened three weeks ago, I changed the fuel pump(it was dying), last week changed to a new fuel filter, and have cleaned the AFM twice within a weeks time. Two days ago when I last cleaned the maf, I bought a new pod filter (Aplexi) and installed it, the old one was dirty and worn. Also before I changed the fuel pump I took out the spark plugs and there was a little black carbon build up on the tops of the plugs, cleaned the plugs.
I have read and researched and it seems that it can be either my maf can be bad even after cleaning it, or bad coil packs, or bad ignitor. I am running a tuned computer and the spark plugs I changed out to are HKS with the correct gap and temp rating.
Changing to a new maf or new/aftermarket coil packs is expensive.
Any suggestions on what might be the problem?
https://www.sau.com.au/forums/topic/464612-questions-about-afm-problems/
Cleaning the AFM will have no effect if the problem with the AFM is not that it's dirty. There are a bunch of other things that could go wrong, the most common of which is dry solder joints inside it. If you do some searching, you will find literally THOUSANDS of thread on here that start just like your post above.
There is only one sensible thing we can advise you. Put the car on a dyno, get a wideband stuffed up its arse, a fuel pressure gauge in the fuel line before the rail, a timing light, an ECU scanner on the Consult port and run the bloody thing until it gives you the problem and then you will at least have some measurements of the important variables likely to be involved. And don't complain that it costs money. We're sick of hearing it.
As to what it could be.....obviously the list includes;
AFM, dead dying or merely needing a resolder.
CAS, dirty sensor, wobbly bearing, poor connection to the loom, etc etc.
Knock sensor dying and causing shit in the ECU.
Fuel pressure reg possibly seizing open or closed instead of controlling properly ( a bit of a stretch, this one).
ECU coolant temp sensor being strange
etc
etc
etc
definitely bad solder joints in your afm, cut it open and resolder them.
etc
etc
etc
Stupid questions, well not stupid, but where is the knock sensor?
I am not having idling problems so would it be a CAS problem? from some of those thousands of webpages I have read, most say that when idling goes bad is when you look into the CAS, TPS, AAC Valve, etc.
Ok, resolder sounds like something that would be easy to do.
Suggestions on what gauge solder to use?
The knock sensor(s) is/are on the side of the block near the oil filter. Do some searching on here for the large numbers of threads.
Bad CAS is more likely to turn up at high revs - especially if it is mechanically bad.
"what gauge solder to use?" The only question on the process that doesn't matter.
yeah its literally open it up, heat up the joints with a tiny bit of extra solder and your done, mine looked fine, heated them up and just literally dabbed extra solder on it to make it liquefy and that's it. solved all my problems which were identical to your description.
It is almost literally a waste of time changing out used parts for used parts. Is your Nismo pump a new one? Yes coil packs are expensive but when they get old they fail so a set of new ones should see you right for the next 20 years. Resoldering the MAF connections will cost you nothing so a good place to start. Did you gap your plugs down to 0.8mm?
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
