1- victoria issue black slim line number plates JDM-034 $500
2- alcon 378mm X 35mm thick replacment discs, unused $500 for the pair- retail for $650 each new
3 - 4" to twin 3" dump pipe stainless steel with a 4" v-band, has a flange to plumb the screamer pipe back into the exhaust, suits a RB26/30 or rb30 $300
4 - Adjustable RB camgears $40
5 - technomagisum 17X9 wheels - pair only $100
6 - 25mm bolt on hub spacers $40
7 - two piece front discs, 365mm hardly used, just been machined $250
8 - Blitz duck tail spoiler with green carbon fibre adjustable blade $450
9 - R34 fibreglass rear gaurds - appox 30mm wider $250
10 - rb26 aftermarket front pipe $70
11 - Alloy radiator 40mm thick $200
all parts located in melboure,
contact via sms or call
tom
0401035221
Edited by tommygr34
https://www.sau.com.au/forums/topic/464620-gtr-parts-r34-rb26-etc/
  • 4 weeks later...
  • 3 weeks later...
up for sale is the Alloy radiator out of my r33 GTR, only reason for the sale as i have changed to a v-mount tube front end and replaced with a shorter alloy radiator. worked perfectly, the engine never ran over 85 degree with 460kw at the track
the tank is 68mm thick, has tabs welded on for the 12" electric thermo fan which is included ( just not in the photo)
few bent fins but doesnt affect performance, can easily been straightened in you has the patience
has fitting for the factory temp sensor and a aftermaket temp sensor
top tank drops down on one side for the factory airbox snorkle on a RB26
located in the south east of Melbourne
$250
0401035221
image.thumb.jpg.57cf9f74efb3181873229f7d
image.thumb.jpg.0328d7f0fef63f90b7962318
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
