I purchased my Jan 92 gtr and realized that for some reason (maybe accident? Idk) they replaced one of the headlights. I want them to be the same and correct for model/year. Anyone know which headlights is the wrong one? It's not a v spec or nismo. Here is a picture. Thanks!
Three key differences between the projectors:
1. Grill mounts for the GT-R grill (apparently mounts can be purchased from Nissan). This is what differentiates GTS and GT-R grills.
2. The bulb type. Early ones are H3C low and the later ones have a weird adaptor and take H1 bulbs. H3C had a wiring adaptor for the H4 to H3, latter H1 takes the H4 plug directly.
3. The shroud/surround, the chrome bit around the projector and high beam reflector. They are slightly different.
They all bolt in the same so it only matters what bulb type you want to run. The projectors are shithouse anyway. Do a retrofit!
Morimoto FX-R + Philips D2S bulb on the left, OEM halogen on the right.
Don't think any re-pinning is required but from memory the holder is different. The H3's have semi circular locators here as the H1 has a flat section. (H3C is the odd one with two pins)
The H3 drops straight in and comes with a ground wire so everything plugs back in.
I think the H1 has the same loose supply ground wire.
Been a while since I looked at my 32's lights, may be getting confused with the S13's.
Maybe look for a pair of N1's?
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
    • How many $$$ do you have to slip cams to logbook a car that’s not the orginal to the 1990 standard lol
    • Thanks for the update I truly appreciate it. I was trying to figure out the sensors.
    • My son recently purchased a 93 Skyline GTS25 (NA), I am hoping to get some insight as to what potential this car has.  I have auto mechanical experience, and I am capable of working on this vehicle, but I know nothing about it.  Where's the best site to purchase parts (maintenance, repair, upgrades)? What kind of upgrades are available?  Thanks again and I look forward to any information that you all have to offer!   Darrick
