Something went wrong with v1 of my 1998 r34 BT1 sedan so I've pulled it to sort it out
Specs were:
RB30 block and crank (with collar, ARP main studs, oil restrictor etc but no drain drilling)
Reimax pump gears, n1 spring in standard rb26 pump
N1 water pump
ATI balancer "1000hp"
Spool rods
Ross pistons
ARP2000 RB26 head studs* (see note below)
tomei 1mm head gasket
R32 RB26 head
HKS 272 poncams
HKS cam gears
GT35R, 6boob, turbosmart 50mm wastegate
ID2000 injectors, single walbro 460 in the tank was dedicated e85
Vipec v44 plug in with MAC boost control
After a couple of hiccups with the build it was all slapped together before Race Wars in 2015 (literally tuned 2 nights before), made ~580hp (430kW) and 700 odd nm on e85 at 21psi
Ran it very hard for a year had various issues
Fried twin plate (upgraded to OS triple)
Boost leaks
Oil pressure dropped to less than 1 bar under heavy braking
Oil leaks (took the spool sump off an put a 25 sump on)
Then the big one - decided to put a bigger turbo on and redo all the piping so I sold the GT35 and front mount off as a kit. Found oil in the coolant so the motor is sitting in a mates workshop at the moment - we will pull it apart and investigate. I suspect using the RB26 studs has caused further issues. The reason it got slapped together in such a hurry was that when the head was put on it the studs stripped the tapped threads out of the block and it all had to come apart for special thread inserts that were meant to hold.
Very rough plan from here is to get the head stripped and inspected. If that's all OK it will get rebuilt with new valve guides and shims and I'm considering lower duration but higher lift cams and double springs.
I have a spare "virgin" 86mm bore block so I will probably transfer the rotating assembly over with new rings and bearings and use RB25 studs.
In terms of oil control this time I will drill out the oil returns in the block, have the head "drain/vent" drain back to the sump instead of a y-piece with the turbo drain and I'll probably put an accusump in the boot.
Then I need to purchase and install a turbo kit and upgrade the fuel system and hopefully the vipec can do flex fuel.
Aim is to go 800hp/600kw at the rear wheels on ethanol, keep it rego'd so I can drive it to work and pick up my son from daycare one day a week, be able to track it at collie (lots of left hand bends), and be able to drop 4th every now and then (only got to do it a few times last year).
  • Like 2
https://www.sau.com.au/forums/topic/464637-1998-bt1-sedan-2630-build-v2/
Have a read of this http://www.sau.com.au/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/?p=7226723
That's a great summary! I'll be sure to use it as a checklist.
I had a similar catch can setup to simon-r32 including the oil drain to sump I just hadn't plumbed up the vent from the sump to the top of the can.
I also had a gated spool sump which leaked and the extra sump capacity didn't seem to make a difference. My preference this time is to use my modified 25 sump and accusump.
It is a bit hard to see it but there's a black alloy protective shield to stop road debris from getting flicked up and hitting it or rubber sticking to it. I used the 20-25psi valve - I think, might need to double check that!
What thread inserts were used to fix the stripped threads?
Have you tested the engine with them in or you have not put it back together again?
Reason i ask is because the RB30 block is already pretty weak in the deck area before going to the larger RB26 studs, adding thread inserts would only weaken it further.
Curious to know which inserts were used and how it goes with them.....
  • Like 1
Sorry if it wasn't clear but the thread inserts were done with v1 and it doesn't appear to have done all that well. Give me a couple of weeks and I'll see if I can produce photo results.
V2 will be going back to rb25 studs in "fresh" block
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
