I imported my R33 V-Spec from Japan in Dec last year, I am having a few engine tuning (missing, loss of power & extremely rich) issues which I am working thru
I have replaced the usual Plugs, AFM, coil packs (replaced with Okada projects for future tuning), injectors tested & cleaned, manifold gaskets replaced...
Turned the V-Cam system off & still the issue remains, next step is an aftermarket ECU
I pulled the ECU out & opened it & i cannot identify what this is?
it seems to have a "Daughter board" stuck on top of the main board (referred from R33 GTR ECU pics )
Questions,
1. Is this STD?
2. If not STD what make is it?
3. can it be tuned?
4. can it be removed so an aftermarket ECU can be fitted?
as I am new to this any help would be appreciated...
https://www.sau.com.au/forums/topic/464654-help-what-ecu-is-this/
# is 2371024U01 of the front of the ECU case
Then ECU # seems to be correct when referenced by Nissan, it is the "piggy back" daughter board that I think has scrambled
The battery was disconnected when shipped & then a few times after that, possibly could have lost or corrupted memory parameters
From my on-line searches it seems to be an "Techtom" board which is apparently tune-able but I am still trying to find how & what program...
Edited by AussieR33GTR
Yes I understand that it is a STD ECU
but when I google R33 GTR ECU this is a STD comp (pic DSC00547)
As mine has a 2nd board (pic 201718) stuck on top, that is what I am trying to find out details about
Ben,
I contacted Matt @ Nistune & he confirmed that it is a TechTom board, thank you for the contact
There are not many people in Australia that can "tune" this board so basically the ECU gets shelved
I am purchasing an Emtron this week so at least there will be unlimited tuning capabilities
I must say that the response time of Matt from Nistune was fantastic...
Ben,
Great you found an answer.
Matt is fantastic, super helpful.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
