I imported my R33 V-Spec from Japan in Dec last year, I am having a few engine tuning (missing, loss of power & extremely rich) issues which I am working thru
I have replaced the usual Plugs, AFM, coil packs (replaced with Okada projects for future tuning), injectors tested & cleaned, manifold gaskets replaced...
Turned the V-Cam system off & still the issue remains, next step is an aftermarket ECU
I pulled the ECU out & opened it & i cannot identify what this is?
it seems to have a "Daughter board" stuck on top of the main board (referred from R33 GTR ECU pics )
Questions,
1. Is this STD?
2. If not STD what make is it?
3. can it be tuned?
4. can it be removed so an aftermarket ECU can be fitted?
as I am new to this any help would be appreciated...
https://www.sau.com.au/forums/topic/464654-help-what-ecu-is-this/
# is 2371024U01 of the front of the ECU case
Then ECU # seems to be correct when referenced by Nissan, it is the "piggy back" daughter board that I think has scrambled
The battery was disconnected when shipped & then a few times after that, possibly could have lost or corrupted memory parameters
From my on-line searches it seems to be an "Techtom" board which is apparently tune-able but I am still trying to find how & what program...
Edited by AussieR33GTR
Yes I understand that it is a STD ECU
but when I google R33 GTR ECU this is a STD comp (pic DSC00547)
As mine has a 2nd board (pic 201718) stuck on top, that is what I am trying to find out details about
Ben,
I contacted Matt @ Nistune & he confirmed that it is a TechTom board, thank you for the contact
There are not many people in Australia that can "tune" this board so basically the ECU gets shelved
I am purchasing an Emtron this week so at least there will be unlimited tuning capabilities
I must say that the response time of Matt from Nistune was fantastic...
Ben,
Great you found an answer.
Matt is fantastic, super helpful.
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
