the system will drain through when you disconnect the lower end of the lines you are replacing.
if you do manage to empty it all out (probably unnecessary) you will need to bleed the system again to getting it running properly. Lift the front wheels off the ground and turn them from lock to lock until you hear the pump sounding happy instead of angry
Ă—
Ă—
