Hey guys,
Not in a rush to sell. Only reason for selling is that I'm an expat from the US here for work and I've learned I won't be staying in Oz for more than about another year due to my job, so I wanted to see if I could find her a new home. I'm in no rush to sell. It's a super clean car and turns heads. You won't be disappointed!
Insurance is paid till January 2017. I'm about to renew the rego for another 3 months this week.
~ Pics ~
3AE6B605-887F-4426-BF49-7B98DEA60BE8_zps
33756105-B55A-4E70-9EA8-DAFC6E855009_zps
0CDFECA7-A29A-494D-8E36-A66CD96DD480_zps
D8DF7724-B863-43F8-8AAD-C58DF2129437_zps
A043EF5C-BAA7-4935-91C4-95AB2AEB870B_zps
~ The Good ~
1999 R34 GT-T - White
115km miles
Full body kit
R34 GTR Spoiler
Nismo Clear Indicators
(4) Rota Grid 18x10's
235/40/18 tires < 12 months old
R34 GT-R struts and springs
APEXi Power FC with new OLED yellow Commander controller - not yet installed
Full 3" exhaust with high-flow cat
Custom FMIC
Decepter Pro BOV with adjustable valve controller
Intake filter
Cube Speed Short-Shifter
Nismo Shift Knob
Turbo Timer
Kenwood CD/DVD double-din unit with wifi air-mirroring
Pioneer and Kicker 6.5" front & rear speakers
Back-up camera
Warlock alarm system with keyless entry and remote start
Sparco Steering Wheel
~ The Not-So-Good ~
Minor scuffs and scrapes on front bar
Original white paint ~ 7 outta 10.
Wheels scrub at full-lock - I think it just needs an alignment. I haven't had time.
Could use some new brake pads.
Throw-out bearing is a bit noisy but still shifts fine.
Price: $20,000
Contact: Mike - zero-four-zero-nine 501-883
Thanks guys!
https://www.sau.com.au/forums/topic/464676-fs-99-r34-gtt-white-south-oz/
  • 3 months later...
  • 3 weeks later...
16 minutes ago, angus said:
is it still available?
Yes, it is. Currently on a different set of Work Emotion 11R wheels, but I still have the black Rota's.6852A4C8-8F48-4E88-A9FC-E811816E8745_zps
Edited by YoshiFD3S
Add picture.
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
