Hi all,
I'v searched both on this forum and on the internet generally and not found a definitive answer to my set of questions.
There is a lot of discussion out there about the TE37 wheels on teh AWD Sytageas but not much at all about them on a RWD Stagea.
My car is a Series 2 C34 Stagea RWD Auto. I want to fit Volk TE37 wheels but they must have the nice concaved look.
If I go for 17s or 18s, what width and offset of wheel could I use ?
Will that offset on a TE37 have that nice concave spoke look ?
https://www.sau.com.au/forums/topic/464680-volk-te37-on-rwd-what-size/
If installed in the right offset, the TE37 spokes bend inwards going from the outside towards the middle. Thus giving the concave appearance which looks nice... see photos attached
That really depends on the thickness of the hub itself. I've seen quite a few wheels with the same width and offset but instead of concave spokes or a bigger dish, they have just had a bigger hub.. I can't tell you why they do this as it makes it a pain to get a full set or 2 full sets of identical wheels.
The reason why i said this, is the te37 could be one of the brands?
staggea1.jpg?w=1000&h=666
The top car at least is a 260RS and will be AWD
Hey Bob what were your track wheels? i remember them being 3 piece and multispoke. Can you post a picture? I really liked them.
Bought them second hand off a drifter - can't remember the brand sorry...
Here ya go - 5 minutes on Google and here's what you are after - they are called TE37 Ultra Evolution Track edition (with what they call "inverted" spokes) - nothing to do with offset - they are available in a range of sizes and offsets. I suspect they will cost an arm and a leg each:
https://www.rayswheels.co.jp/products/wheel.php?lang=en&wheel=TE37ULTRA-TE
If you had bothered to click on the Link to Rays Engineering that I gave you you will see that this statement is incorrect (as is your statement that you know the model of wheel you are after). It is the particular model of TE37: "Ultra Evolution Track Edition" that gives them the inverted spoke look that you are after - nothing to do with offset - as i have already told you they are available in a full range of offsets ALL of which feature the "reinverted spokes".
17 or 18 x 8in or 9in will fit. For offset I have no idea for your car - for mine it requires different offsets front and rear.
According the the web site they only come in a 20" rim size for the ultra track edition and 19" and 20" for the Ultra
Yes quite right. Which confirms my theory that the wheels on the 260Rs cars above are Varrstoen copies (not forged but cast) which do come in 17 18 and 19 inch. Others making similar knock-offs include Koya and Rota.
I did bother to look at the link.
Reading through it and finding that, the "track edition" is not available in rim size 18" confirmed to me that it is not the only edition that can give the inverted spoke look.
The photos below are of a car which has Volk TE37 in 18" ... not replica. These photos show the wheels to have that inverted spoke appearance which I am after.
Edited by ceejay
I found a couple of the TE37SL variants have that look.
That is right Sir. That is exactly what I am saying too. There are several of the TE37 versions that have the inverted spoke appearance.
The spokes look more and more concave as the outer edge of the rim moves further and further towards the outside of the car, compared to the position of the hub. negative offset or the smallest positive offset.
What I want to know is, say for 17" and 18" wheels, (never mind what brand or style) what is the width and maximum offset usable, which will bring the edge of the wheel closer to the outside of the vehicle but still not cause fouling with the wheel arches.
Edited by ceejay
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
