Hi all,
I'v searched both on this forum and on the internet generally and not found a definitive answer to my set of questions.
There is a lot of discussion out there about the TE37 wheels on teh AWD Sytageas but not much at all about them on a RWD Stagea.
My car is a Series 2 C34 Stagea RWD Auto. I want to fit Volk TE37 wheels but they must have the nice concaved look.
If I go for 17s or 18s, what width and offset of wheel could I use ?
Will that offset on a TE37 have that nice concave spoke look ?
https://www.sau.com.au/forums/topic/464680-volk-te37-on-rwd-what-size/
If installed in the right offset, the TE37 spokes bend inwards going from the outside towards the middle. Thus giving the concave appearance which looks nice... see photos attached
That really depends on the thickness of the hub itself. I've seen quite a few wheels with the same width and offset but instead of concave spokes or a bigger dish, they have just had a bigger hub.. I can't tell you why they do this as it makes it a pain to get a full set or 2 full sets of identical wheels.
The reason why i said this, is the te37 could be one of the brands?
staggea1.jpg?w=1000&h=666
The top car at least is a 260RS and will be AWD
Hey Bob what were your track wheels? i remember them being 3 piece and multispoke. Can you post a picture? I really liked them.
Bought them second hand off a drifter - can't remember the brand sorry...
Here ya go - 5 minutes on Google and here's what you are after - they are called TE37 Ultra Evolution Track edition (with what they call "inverted" spokes) - nothing to do with offset - they are available in a range of sizes and offsets. I suspect they will cost an arm and a leg each:
https://www.rayswheels.co.jp/products/wheel.php?lang=en&wheel=TE37ULTRA-TE
If you had bothered to click on the Link to Rays Engineering that I gave you you will see that this statement is incorrect (as is your statement that you know the model of wheel you are after). It is the particular model of TE37: "Ultra Evolution Track Edition" that gives them the inverted spoke look that you are after - nothing to do with offset - as i have already told you they are available in a full range of offsets ALL of which feature the "reinverted spokes".
17 or 18 x 8in or 9in will fit. For offset I have no idea for your car - for mine it requires different offsets front and rear.
According the the web site they only come in a 20" rim size for the ultra track edition and 19" and 20" for the Ultra
Yes quite right. Which confirms my theory that the wheels on the 260Rs cars above are Varrstoen copies (not forged but cast) which do come in 17 18 and 19 inch. Others making similar knock-offs include Koya and Rota.
I did bother to look at the link.
Reading through it and finding that, the "track edition" is not available in rim size 18" confirmed to me that it is not the only edition that can give the inverted spoke look.
The photos below are of a car which has Volk TE37 in 18" ... not replica. These photos show the wheels to have that inverted spoke appearance which I am after.
Edited by ceejay
I found a couple of the TE37SL variants have that look.
That is right Sir. That is exactly what I am saying too. There are several of the TE37 versions that have the inverted spoke appearance.
The spokes look more and more concave as the outer edge of the rim moves further and further towards the outside of the car, compared to the position of the hub. negative offset or the smallest positive offset.
What I want to know is, say for 17" and 18" wheels, (never mind what brand or style) what is the width and maximum offset usable, which will bring the edge of the wheel closer to the outside of the vehicle but still not cause fouling with the wheel arches.
Edited by ceejay
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
