The mods they is will all ready has.
Front Mount return Flow so no cutting up the car
Nistune
Hks Type S gtr oil cooler
hks front pipe
hks TI Exhaust
650cc injectors
HKS Reloaded racing pod filter set up
more to come when i remember josh
mmmk i get what you are saying been told 230rwkw is what it would make was making the car to spoll fast i.e kinda wana do some trmac rally one days lmao. ah so would it spol faster then a high flow? Would it be possible to use a diff rear housing then .64?
Edited by Outcast
yea get what you are saying the gt2510 has been mach ined out to take the gt3071 so should be making more power then 210 with them mods no? P.S the turbo has been highflowed to fit the gt3071 so should make more hp right?/
Edited by Outcast
Its sounds like a bastardized mongrel turbo. You could buy it waste a few hours putting it on and tuning $ and then let us all know if it works out. I'm with Ben, hg highflow bolt on. Its proven and u know what your getting. But up to you.
Just drop the idea of using that bits and pieces turbo. It will be shit and give you lots of problems. Just buy a standard blown up R33 turbo and get it high flowed. It's a bolt on affair and will be oh so easy compared to this frankenturbo.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
