dstylez Posted July 23, 2004 Share Posted July 23, 2004 so in essence this device works the same way an EBC does? Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-948996 Share on other sites More sharing options...
Bass Junky Posted July 23, 2004 Author Share Posted July 23, 2004 dstylez exactly. Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-949011 Share on other sites More sharing options...
R33vit Posted July 23, 2004 Share Posted July 23, 2004 Im not convinced. As soon as a boot it ive got full boost, so how does this give me boost quicker?? Maybe on the tested Audi, they had some inbuilt delayed boost in the computer? Robo's I use this boost controller and it does seem like boost comes on quicker but what it does with the use of the second valve stops wastegate creep. Like all bleed valves they to suffer in the higher gear. Boost drops a little in 4th. You could get it out but takes a lot of road testing and draws a sh1t load of attention to your self Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-949014 Share on other sites More sharing options...
Guest Robo's Posted July 23, 2004 Share Posted July 23, 2004 Well, seeing with my new actuator, im actually down 2psi in the lower revs. Im still experimenting with it, but i maybe convinced by this. Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-949115 Share on other sites More sharing options...
Bass Junky Posted July 23, 2004 Author Share Posted July 23, 2004 Components. Well the components just arrived. Here's a pic to show you them. The fitting aren't what I expected but will do the job. They are all stainless steel, and I might change them over to normal ones, as the barbs aren't part of the elboxs and Ts but actually screw in. this meants more components and makes the whole set up quite large. I'll build my one this weekend and gauge the results and source some more appropriate fittings next week. Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-949976 Share on other sites More sharing options...
Trust33 Posted July 23, 2004 Share Posted July 23, 2004 hey bass junky.Encase the link so you can actually push and go.Ill show you how to do it. Written like this but without the spaces: Bass Junkys Boost controllers [ url/ ] Looks like this Bass Junkys Boost controllers[url/] Your link is soived.... Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-950108 Share on other sites More sharing options...
Trust33 Posted July 23, 2004 Share Posted July 23, 2004 Components.Well the components just arrived. Here's a pic to show you them. The fitting aren't what I expected but will do the job. They are all stainless steel, and I might change them over to normal ones, as the barbs aren't part of the elboxs and Ts but actually screw in. this meants more components and makes the whole set up quite large. I'll build my one this weekend and gauge the results and source some more appropriate fittings next week. Hey bass junky.Encase the link so you can actually push and go.Ill show you how to do it. Written like this but without the spaces: Bass Junkys Boost controllers [ url/ ] Looks like this Bass Junkys Boost controllers Your link is soived.... Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-950116 Share on other sites More sharing options...
Trust33 Posted July 23, 2004 Share Posted July 23, 2004 Components.Well the components just arrived. Here's a pic to show you them. The fitting aren't what I expected but will do the job. They are all stainless steel, and I might change them over to normal ones, as the barbs aren't part of the elboxs and Ts but actually screw in. this meants more components and makes the whole set up quite large. I'll build my one this weekend and gauge the results and source some more appropriate fittings next week. Hey bass junky.Encase the link so you can actually push and go.Ill show you how to do it. Written like this but without the spaces: Bass Junkys Boost controllers [ /url ] Looks like this Bass Junkys Boost controllers Your link is soived.... Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-950124 Share on other sites More sharing options...
Trust33 Posted July 23, 2004 Share Posted July 23, 2004 Components.Well the components just arrived. Here's a pic to show you them. The fitting aren't what I expected but will do the job. They are all stainless steel, and I might change them over to normal ones, as the barbs aren't part of the elboxs and Ts but actually screw in. this meants more components and makes the whole set up quite large. I'll build my one this weekend and gauge the results and source some more appropriate fittings next week. Hey bass junky.Encase the link so you can actually push and go.Ill show you how to do it. Written like this but without the spaces: Bass Junkys Boost controllers [ /url ] Looks like this Bass Junkys Boost controllers Your link is soived.... Hope you have luck with selling the boost controllers:) Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-950130 Share on other sites More sharing options...
bangahh Posted July 23, 2004 Share Posted July 23, 2004 Interested, whats the final price and can you please do a dummys guide to installing it. ie step by step instructions. Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-950580 Share on other sites More sharing options...
evade Posted July 24, 2004 Share Posted July 24, 2004 Whats the process in adjusting these to your needs? Or whats the deaL? Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-951110 Share on other sites More sharing options...
benm Posted July 24, 2004 Share Posted July 24, 2004 If you haven't already read the 2 articles on Autospeed.com i'd highly suggest it. Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-951113 Share on other sites More sharing options...
Bass Junky Posted July 25, 2004 Author Share Posted July 25, 2004 Okay, please see this thread now. Build will be going ahead. http://www.skylinesaustralia.com/forums/sh...2978#post952978 Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-952980 Share on other sites More sharing options...
Bass Junky Posted July 26, 2004 Author Share Posted July 26, 2004 See other thread again for price drop. I got better prices...... Link to comment https://www.sau.com.au/forums/topic/46469-eoi-autospeed-diy-boost-control-kit/page/2/#findComment-954774 Share on other sites More sharing options...
