Good day everyone, I'm new to this sight and I'm not even sure if I'm doing this right or posting this in the right section or not. I have a skyline r34, it has the rb25det neo motor, I have an issue that nobody can seem to solve, please can someone advise or give help. I'm from south africa and we don't get the skyline this side so I had to import mine, so not many guys have experience in fixing this car. Firstly the car was stock.when I came to upon this issue the car would loose power like it dropped a valve but it would happen.every now and again, I had it checked out I was told my spark plugs were wrong so I did research on sights got the right plugs and even gapped it to 0.8mm the car ran fine for awhile then the same issue returned about a month later, I then replaces the coils, once again it worked for a month then the problem returned, some said my ground of the car was not right. I sorted that out but the problem was still there, I then changed my injectors found out one was faulty. The car worked fine for about 3 months then the issue came back and shortly after that the piston melted and the xonrod shot through the block I replaces the motor and put a spitronics management system in now my engine light doesn't want to go offend the new motor is giving the same problem. I don't know how to.fix this issue. Please some advice would be great.
https://www.sau.com.au/forums/topic/464702-need-help/
  • 4 months later...
First off stay out of boost until you have a handle on what is going on with the car.
Two start eliminating problems.
Check fuel pump and fuel pressure.
Use multimeter to check earth's
Your check engine light is triggered by the ecu.
Trace the wireing to your ecu and double check every single pin on the ecu harness vs the plug on the engine.
Read the ecu manual to see if it's doing something daft.
Get your car on a load bearing dyno and post a dyno graph.
With Afr and boost.
https://www.sau.com.au/forums/topic/464702-need-help/#findComment-7775537
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
    • Dashcams Australia (13/05/25) captured JDMHSE (Vic plate) being a right tosser.
    • Wish someone would start a racing series for Group A replica cars, a bit like Touring Car Masters but for 1985 onwards and not grandpa's falcon and/or Monaro. I know they race in some historic class but that's for original cars, no replicas allowed.
