This item is basically new - I have used it twice, bought it for track days however car wont be ready for some time yet :(
Price - $500
Also comes with a suction kit.
Located in Melbourne.
GoPro HERO3+ Black Edition
If you like filming extreme sports or hoping to film sporting events but are concerned that the environment will damage a normal camera, then the GoPro cameras will be the best solution for you. The GoPro Hero3+ Black edition is the most advanced camera in the GoPro product line. Comparing to its predecessors, it is smaller, lighter, and 2x more powerful. It is capable of shooting footages at HD resolution (including wide angle) at a high speed to capture every moment. In addition, the GoPro Hero 3 Black Edition comes with a remote and embedded with Wi-Fi capability to enhance user control. There are many other incredible features that put this product at the top position of the action camera industry.
Key Features
Professional 4K Cinema 15 fps / 2.7K cinema 30 fps / 1440p 48 fps / 1080p 60 fps / 960p 100 fps /720p 120 fps and more video capture
12MP photo capture with 30 fps burst
Wi-Fi Built-In
Wi-Fi Remote Compatible (included)
GoPro App Compatible (FREE)
197/ 60m Waterproof Housing
Assorted mounts and hardware included for attaching to helmets, gear and more
  • 1 month later...
  • 2 months later...
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
