This item is basically new - I have used it twice, bought it for track days however car wont be ready for some time yet :(
Price - $500
Also comes with a suction kit.
Located in Melbourne.
GoPro HERO3+ Black Edition
If you like filming extreme sports or hoping to film sporting events but are concerned that the environment will damage a normal camera, then the GoPro cameras will be the best solution for you. The GoPro Hero3+ Black edition is the most advanced camera in the GoPro product line. Comparing to its predecessors, it is smaller, lighter, and 2x more powerful. It is capable of shooting footages at HD resolution (including wide angle) at a high speed to capture every moment. In addition, the GoPro Hero 3 Black Edition comes with a remote and embedded with Wi-Fi capability to enhance user control. There are many other incredible features that put this product at the top position of the action camera industry.
Key Features
Professional 4K Cinema 15 fps / 2.7K cinema 30 fps / 1440p 48 fps / 1080p 60 fps / 960p 100 fps /720p 120 fps and more video capture
12MP photo capture with 30 fps burst
Wi-Fi Built-In
Wi-Fi Remote Compatible (included)
GoPro App Compatible (FREE)
197/ 60m Waterproof Housing
Assorted mounts and hardware included for attaching to helmets, gear and more
  • 1 month later...
  • 2 months later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
