Having the usual airbag light issue and cannot now cancel it by the ignition key method, had a diagnostic on it and the code B1161 CRD RH open was in history. Chris Rogers is saying new seat belts at $600 + each is the solution can anybody offer an alternative solution.
https://www.sau.com.au/forums/topic/464763-airbag-flashing-light-codes/
I'm pretty sure I had that code when I removed standard seats as the new ones are Recaros so don't have the airbag plug etc underneath. Sounds like maybe the unit in the seat has crapped itself. Try putting in a new seat or unplugging the seat side of the harness and wiring a 2.2ohm resistor into the body side harness.
Scott those numbers came up when Matty scanned the car, he,s previously had issues with airbag lights on different brands which have been bad connections, an item in the steering wheel and various others all a lot cheaper than new seats/belts
If I recall, using a cable tie to tighten the two ends of the connector together fixed the warning light for some people in the past (never had it personally, so can't confirm).
Might be worth a try before anything else?
Standard factory cloth seats Phil and all the plugs look to be ok but thanks for the offer of the seats will keep it in mind, really pisses me off that Nissan can build such a good car then stuff things up like this silly bloody airbag issue.
Before touching ANY airbag circuitry, disconnect both positive & negative battery terminals & wait 5-10 minutes before disconnecting anything. Not doing so can cause issues. The majority of airbag components/systems MAXIMUM resistance is 4 Ohmns. Anything over this will result in a fault.
Its likely damage has occurred to the seat belt SRS ram (pyrotechnic device) when you changed your seats.
    • Update Issues 5 (plus #4) - 10 After making a claim about issue #4's missing part, DeAgostini Japan sent a whole new issue #4 and it arrived about 2 weeks after that. That was back in early March. It took another 4 weeks to receive issues 5 - 13 though. This update is for issues 5 - 10. Ove the 5 issues the front left suspension and most of the engine have been completed. The quality of the castings and fit of the parts is quite good, it seems better than DeAgostini's BNR34 Skyline GT-R from the Fast & Furious 2 movie, which (to me anyway) doesn't seem to have as tight tolerances or quite as accurate castings.  Each issue has a lot of info about the 1989 - 1993 Skyline range and other Nissan models from that era, but the focus is on the BNR32 Skyline GT-R Nismo and the various racing it did in Japan, Europe (Spa 24hrs) and of course Australia. I've included some text translated with Google Lens in some photos and will add to them if there's anything worth including.
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
