Hi everyone!
I am new to the forum, and after years of reading the forums thought i would join and start tackling a few jobs on the car. I have a couple questions that I'm sure someone on here could answer!
I had to replace my MAF sensor, the part arrives in a few days. Just wanted to know if i can just reconnect the new MAF and start driving or if i have to do anything else before or after i can use the car again?
And also. I am currently running a K&N filter (the kind you oil) but have read that this sort of filter can be bad for the MAF so am looking at a HKS mushroom filter. Just wanted to know what dimensions for the filter i will need for it to fit in my car (series 2 R33 GTST). To connect it to the MAF etc.
Thanks guys, much appreciated!
https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/
Welcome to SAU dtrants :)
Just put the new maf onto your airbox, plug it in, and start driving.
The maf od is 3" so any 3" pod will fit. But you will need an adaptor. They can be found online or ebay etc.
I used to use a k&n panel filter. I washed it with cold water then let it dry and it was fine for 6 months until I changed my setup. If there are any remnants of oil on the filter and it does make a film over your new maf, get some contact cleaner and spray the maf wire and it should clean it up.
  • Like 1
I actually saw one of those filters fail on Facebook the other day. The nut came off and went straight into the turbo. Plenty of people have used them with no dramas, and it was the first time I have ever seen it happen. So up to you.
I just use the cheap ones from supercheap etc.
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
