dtrants Posted May 12, 2016 Share Posted May 12, 2016 Hi everyone! I am new to the forum, and after years of reading the forums thought i would join and start tackling a few jobs on the car. I have a couple questions that I'm sure someone on here could answer! I had to replace my MAF sensor, the part arrives in a few days. Just wanted to know if i can just reconnect the new MAF and start driving or if i have to do anything else before or after i can use the car again? And also. I am currently running a K&N filter (the kind you oil) but have read that this sort of filter can be bad for the MAF so am looking at a HKS mushroom filter. Just wanted to know what dimensions for the filter i will need for it to fit in my car (series 2 R33 GTST). To connect it to the MAF etc. Thanks guys, much appreciated! Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/ Share on other sites More sharing options...
Trex Posted May 12, 2016 Share Posted May 12, 2016 Welcome to SAU dtrants Just put the new maf onto your airbox, plug it in, and start driving. The maf od is 3" so any 3" pod will fit. But you will need an adaptor. They can be found online or ebay etc. I used to use a k&n panel filter. I washed it with cold water then let it dry and it was fine for 6 months until I changed my setup. If there are any remnants of oil on the filter and it does make a film over your new maf, get some contact cleaner and spray the maf wire and it should clean it up. 1 Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7726375 Share on other sites More sharing options...
dtrants Posted May 12, 2016 Author Share Posted May 12, 2016 Thanks for the fast reply Trex! Are you able to give me an idea of what to search for? Like keywords to find the adapter I need. I'm a newbie to this stuff ? Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7726378 Share on other sites More sharing options...
Trex Posted May 12, 2016 Share Posted May 12, 2016 you're in luck, i was already on ebay http://www.ebay.com.au/itm/Plastic-Filter-Adaptor-CALPA9-SFA9-Brand-NEW-Super-Cheap-Auto-/221960504582?hash=item33ade08506:g:T54AAOSwqu9VJkey Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7726380 Share on other sites More sharing options...
dtrants Posted May 12, 2016 Author Share Posted May 12, 2016 Perfect! And do you think this filter would be ok for that adaptor? http://www.ebay.com.au/itm/HKS-Super-Air-Performance-Pod-Filter-3-80mm-/111772865321 Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7726397 Share on other sites More sharing options...
Trex Posted May 12, 2016 Share Posted May 12, 2016 I actually saw one of those filters fail on Facebook the other day. The nut came off and went straight into the turbo. Plenty of people have used them with no dramas, and it was the first time I have ever seen it happen. So up to you. I just use the cheap ones from supercheap etc. Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7726402 Share on other sites More sharing options...
dtrants Posted May 12, 2016 Author Share Posted May 12, 2016 Ok cool, thanks heaps for your help mate! Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7726407 Share on other sites More sharing options...
niZmO_Man Posted May 12, 2016 Share Posted May 12, 2016 I would stay away from those "mushroom" style filters, they are garbage. Paper filter works fine. If you want to spend a lot more than $10, get Apexi ones. Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7726489 Share on other sites More sharing options...
Burger Posted May 12, 2016 Share Posted May 12, 2016 Yep, Apexi is the way to go. $139 from JustJap. http://justjap.com/apexi-power-intake-kit-nissan-skyline-stagea.html Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7726498 Share on other sites More sharing options...
dtrants Posted May 12, 2016 Author Share Posted May 12, 2016 Thanks for the replies guys, i will look into them! 1 Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7726528 Share on other sites More sharing options...
Glennno Posted May 16, 2016 Share Posted May 16, 2016 Thoughts on the 3A Racing pod's? Have heard some good things about them. Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7727936 Share on other sites More sharing options...
dtrants Posted May 16, 2016 Author Share Posted May 16, 2016 Just a quick update, new MAF came today, installed it into the car and its running significantly better than when i had the old one in. Happy days! 1 Link to comment https://www.sau.com.au/forums/topic/464774-new-maf-and-air-filter/#findComment-7728045 Share on other sites More sharing options...
