Hi guys im wondering how most guys replace valve guides. I can take them out but i just dont know how to install them. I have a 50 ton press and can press them out but i cant find a way to angle the head to press it out unless i see my self making a jig to hold the head. Im just wondering how or what methods the machinist use to replace valve guides. I looked it up on you tube and all. But cant seem to find any on a rb26. I see old chevy heads and so on. Is there a specific tool i can buy to do the job. ??
I did make a tool and with brut force i hammered them out worked great. Oh that was on a junk head as a test. But i just cant find a specific process used on rb26 heads.
Thanks in advance.
Dont just press the guides in. Heat the head and freeze the guides. Have repaired a head with galling from the previous shop installing the guides like a neanderthal
Would have to watch how hot the head gets or seats could droo out. This is a very touchy decision. Lots of ways of doing it.from what i see.
  • 3 weeks later...
Sorry for all late reply. I was planning on doing the guides myself on a junker before i do it on my new heads. I just got 5 sets of bc guides. I also located a very good tool that removes and installs the guides.
One question. Do anyone know or heard of using seal lock/fluid weld on the guides like a locktite to keep them in. I know its a tolerance fit thing and freezing them before installing them is a good idea as well. Just was reading up on some old article, and came across the fluid weld stuff. Oh and i am planning on doing all my valve work myself its always worked out for me, just my first time having a failed guide. Hate this. I hope this is the last hump in the rb line up. I tight for years to master the oil issues, did it and over looked the guides. Damn me. With fully built motor is there any other weak point i may have mist.
Thanks in advance.
Best to get a junk head and do some practice runs before you screw up your good one. Are you planning on reaming the guides, grinding the valves and cutting the seats yourself too?
When you say reaming the valve you mean kind of like drilling them out cutting the side wall area down so that they come out easier. Rather than pressing them out and scolding up the aluminum.???
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
