Hey guys,
Couple questions in regards to modifications to an rb25det neo in an R34
If I decide on dropping in Tomei poncams, would I need to upgrade springs and retainers too?
Obviously it would be beneficial to do so however due to potential budget restrictions, it may not be an option
If the answer is yes, then I may turn my current internally gated Hypergear Atr43ss2 into external gate and be able to afford to do valve springs and retainers
If the answer is no, then I may use the funds to upgrade to an externally gated Atr45 instead
Any input, advice or feedback is appreciated
Thanks
Edited by Swole
https://www.sau.com.au/forums/topic/464905-rb25det-neo-mod-questions/
I would think by the time you buy a gate and modify pipe work you won't "make" any cash
Which cams? How hard do you plan to spin the motor? What are you using it for?
Tomei 260 drop ins
Aiming for around 350rwkw mark on eflex
Using it mainly for street use
True, however that would still cost less then buying an Atr45 with chra roller bearing + labour then to externally gate my current one :)
Well, the definition of "drop in" implies that you don't need to change anything else. But when you couple the increased mechanical loads from the cam AND the boost level you need to make 350rwkW, you do start to worry about valve float. As usual, YMMV. I'd suggest that the usual approach is to suck it and see. That doesn't work if total budget is a problem though. If it were me, I'd not change the cams at all, and save all the money.
This is true
Thanks
A good stock Neo engine doesn't valve float we were running them toward 30psi and they are fine.
The Cams are not required on the Neo either. Stock cams on ATR45SAT is good good enough to support towards 400rwkws on E85 fuel.
For externally gated setup the ATR45SAT in Ceramic ball bearing setup will be making alot more power then the ss2, and specially if its an older version SS2 its not laggier. You can get some where towards 370rwkws using it internally gated. But it needs a big PWR cooler and at least 4 inches exhaust to get there.
I was going to PM you later down the track asking whether I would need to upgrade valve springs and retainers (or even head gasket) to make close to 400rwkw with an ATR45 roller bearing!
Cams has simply been a long term personal goal for me haha
Thanks
Edited by Swole
i have tomei type b cams in mine, as well as an older SS2 ex gate currently making 324kw on 16 psi and e70. with bigger injectors (maxed 725cc atm) and more boost mine would see 350kw+ easy on e85 :) just an indication of what you could do
Spend your money on turbo, wastegate, fmic, exhaust, injectors, fuel pump, AFM if necessary, (I presume you already have an aftermarket ecu or a Nistune chip) - these are the priorities - you can save up for cams later if you really want.
That's awesome
Planning on upgrading the injectors?
If I can get away with it, I might go with an ATR45 with cams on flex/85 and aim close to 400rwkw
Already got a complete Plazmaman set up including plenum, throttle and intercooler running a Haltech ps2000. Gotta upgrade the injectors and pump for 85 which I've already included in my budget :)
Edited by Swole
That's awesome
Wont be upgrading injectors im happy with it for now... i have other plans for the car atm. Why not go a gtx35r and faceroll 400kw?
Fair call
Correct me if I'm wrong cause I haven't looked much into it, but an ATR45 is cheaper and I'm staying low mount
ATR45 has also been proven to exceed 400rwkw, however that's with upgraded springs and pistons
I'll be consulting with Tao on whether I'd be able to get away without upgrading those to achieve close to, if not, 400 on e85 :)
For my 10c I believe there is type A and B Poncams for the Neo Turbo 25 and I would go for the type As or OE cams .
From memory the type As are about 252 duration and the type Bs 260 .
Where the Neo has it over the R33 25DET engine is a bit more lift and more aggressive lift ramps on the cams . This obviously didn't work with the R33s hydraulic buckets hence the solid ones and shim adjustment .
I believe Nissan was looking to pull the torque peak down the rev range on the GTt hence better valve train and different inlet manifold volume .
I think the longer period B cams would cost you low down part throttle torque and be less suited to the NEOs manifold .
One here with a Neo type Stag went B cams and regretted the decision later .
You call , mine would be standard or at most the shorter Poncams .
A .
A .
Correct
However I do want the 260 duration
Dont these neo guys rev out higher than r33's, ive seen them go well over 7k which type b's would be in the zone. I got some for the 2530neo so hopefully they'll aid the flow
Mine does
Standard cams/springs/retainers good for over 400kw. Nissan did good, leave it standard.
This is what I'm thinking
What's wrong with stock cams?
Recently a R34 done by Chequered Tuning spun over 400kW using a Hypergear ATR45SAT turbo.
Nothing's wrong
Oo was that unopened head?
Cams have just been a goal for myself, really just after the lump/response shockingly haha
Main question is whether I'd need to also upgrade the springs/retainers/(headgasket) if I did cams and went for 400rwkw :P
Appreciate all the input though!
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
