I could save so much if I didn't open it but I think it's worth the safety haha
Haven't heard anything bad about the 1.3mm cometic HG so think I'll stick with that one
FYI.. Matt Wooten makes probably same power as myself and regularly tracks his car too.. he doesn't even have head studs and the motor is still performing (Neo motor).
No need to pop the head and do a headgasket if you're not shooting north of 400kW in my opinion.. and if you get close to that, time to build the rest of the bottom end.
I was thinking of actually asking him a few questions too about his build!
Just wanted mine to be safer if I accrued the extra cash and if I had the patience
Edited by Swole
are you racing your car?
are you tracking it?
if it's just a streeter with some drag racing just drop in studs and torque them up well and spend the remainder of your cash on hookers, cocaine and molly LOL...jk.. buy a decent radiator, oil cooler and a 1.5/2 way LSD to put the power down.
Will mainly be a weekender, occassional drag and it might see the track once every 2-3 years
Love your other ideas though haha!
But I do plan on getting an ASI rad and China spec cooler as mentioned in my other thread :)
Hi bro. The reps leak better off getting the real deal.. if you go onto golebys site you can get any spring rate you want.. i just changed my 2 bolt wastegate to the 45mm vband style and to what spring rating you need have a chat to ya tuner.. Cheers
How much boost and rpm do you plan on running?
If it's 18-22 psi and 7000rpm don't do anything to the head just get at gt3076r or similar sized turbo with external gate. If you plan on running around 25 plus Padi and around 8000rpm to keep it reliable will cost quite a bit more than just head studs and valve springs
Yeh def getting the real deal haha
Plan on getting the ATR45 external gate which is equivalent to the 3076 :)
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
