I could save so much if I didn't open it but I think it's worth the safety haha
Haven't heard anything bad about the 1.3mm cometic HG so think I'll stick with that one
FYI.. Matt Wooten makes probably same power as myself and regularly tracks his car too.. he doesn't even have head studs and the motor is still performing (Neo motor).
No need to pop the head and do a headgasket if you're not shooting north of 400kW in my opinion.. and if you get close to that, time to build the rest of the bottom end.
I was thinking of actually asking him a few questions too about his build!
Just wanted mine to be safer if I accrued the extra cash and if I had the patience
Edited by Swole
are you racing your car?
are you tracking it?
if it's just a streeter with some drag racing just drop in studs and torque them up well and spend the remainder of your cash on hookers, cocaine and molly LOL...jk.. buy a decent radiator, oil cooler and a 1.5/2 way LSD to put the power down.
Will mainly be a weekender, occassional drag and it might see the track once every 2-3 years
Love your other ideas though haha!
But I do plan on getting an ASI rad and China spec cooler as mentioned in my other thread :)
Hi bro. The reps leak better off getting the real deal.. if you go onto golebys site you can get any spring rate you want.. i just changed my 2 bolt wastegate to the 45mm vband style and to what spring rating you need have a chat to ya tuner.. Cheers
How much boost and rpm do you plan on running?
If it's 18-22 psi and 7000rpm don't do anything to the head just get at gt3076r or similar sized turbo with external gate. If you plan on running around 25 plus Padi and around 8000rpm to keep it reliable will cost quite a bit more than just head studs and valve springs
Yeh def getting the real deal haha
Plan on getting the ATR45 external gate which is equivalent to the 3076 :)
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
